09-03-2023, 06:48 PM | #1 |
Rep 1
No Speedometer!
Hello guys, any help will be appreciated.
On 9/1 i pick up my M6 from shop after fixing carbon fiber roof! did not noticed speedometer until i got home and drive away, when i check the speedometer it stayed at 0 mph. Any of you with the same problem here? Thank you so much. |
09-03-2023, 11:25 PM | #2 |
Rep 631
If you did not get an ABS warning then it is not the wheel speed sensor. A faulty wheel speed sensor will give an ABS fault light. If not, it is likely in the dash/gauge or the signal from the the computer.
