      06-17-2014, 12:46 PM   #23
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Nice thread... more pics. good info
My Thread:
      06-17-2014, 12:47 PM   #24
78mao
78mao's Avatar
Taiwan
133
Drives: F10, F13, current->F80, F15 X5
2015 M3 BMW M3  [1.00]
more pics of the whole car please! Looks awesome!
      06-17-2014, 03:31 PM   #25
m6beast
m6beast's Avatar
185
Drives: stock m6
A/F's and DYNO on BMS STAGE 1 meth integration
Originally Posted by michel lane View Post
That's great reading ,this tells me that the ecu operates on 02 feedback ,similar to the vettes running bigger cams and headers . I guess it needs time to re-calibrate its map on the various pulls . It's nice to know that the AFR reading becomes better during the course f the week.
Here's a link I've posted to give some insight
http://www.n54tech.com/forums/showthread.php?t=25417
      06-18-2014, 06:00 PM   #26
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
Some pictures of the car.....
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE
SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19
      06-18-2014, 06:51 PM   #27
Exium
Exium's Avatar
Mexico
Drives: 2013 M6 Gran Coupé
Matte Gray and black rims + M6 GC´s power = Perfect combination
2013 M6 Gran Coupé
Imperial Blue metallic|Competition Package|
      06-19-2014, 07:24 AM   #28
Andym3100k
Singapore
110
Next tue I should be getting my S2 board n Nozzles, thereafter I will hit the dyno to see what is the gain.
+6psi here I come........
      06-19-2014, 12:15 PM   #29
m6beast
m6beast's Avatar
185
Drives: stock m6
Make sure you let it adapt before you dyno. Don't forget to purge the system before you run the car and before you dyno to make sure you don't have any air in the lines, otherwise it won't boost at its full potential. After you purge kick it on the highway a couple of times to make sure meth is flowing consistently. 3rd or 4th gear are good long gears to see and feel meth flowing.
" You'll notice at first there well be a little delay since the meth has to flow after purging the system."
The best way is to datalog it so you can see how boost is running. there might be some dips in a couple runs till meth is running continuously. A couple of runs or pulls you'll be good to go.
Good luck!
Car looks great by the way!
      06-19-2014, 12:24 PM   #30
Andym3100k
Singapore
110
Good luck!
Sure, will do that. Thanks a lot Bro!
      06-26-2014, 05:07 AM   #31
Andym3100k
Singapore
110
Good luck!
I must really thank M6beast for his advice, guess what? While I'm still waiting for my S2 board for meth. I pour VP 100 octane race gas to test out on +5psi & what I can said is I'm freaking surprise with the result. I don't have any misfire or whatsoever experience that I had the last time (misfire on 4 cylinder & transmission problem) the car pull like a bullet train just after a few rounds of adaption. I don't even have to leave it overnight or a few days of waiting.
I'm now telling every M5/M6 owner, this Engine & Transmission is not what u may be thinking of (as of it is very limited) The last time when I hv misfire I was on 4.5psi with 98ron with 1 bottle of +6 Ron booster. I will keep trying all different kind of fuel with different boost. I don't think it will misfire or with all kind of funny code again, the method is very easy just let it adapt. Do it with 3rd gear n 4th gear & DO NOT step on the gas in a short second. Just press it down slowly to run the engine pull to redline n let it feel the pull & adapt to the mix of the AF. Repeat the same thing for 5, 6 times if possible then stop shut the engine for a while like 10, 20mins n start the car n repeat again. After which I can tell u the car will be totally different!
U will not believe till u try it, last night I push it to 5.5psi with race gas(without meth) even higher than what M6beast did on 5psi. The car will just keep pulling......
Heading to the same dynamic dyno very soon, stay tune.......
      09-04-2014, 10:23 AM   #32
Black Sparrow
Drives: ///M
Is this your 640i? The side mirrors aren't M6 mirrors
      09-04-2014, 06:38 PM   #33
Andym3100k
Singapore
110
Yes as mentioned in the early post some pics was taken on the 640i n later transfer over to the M6 with all the WIDEBODY kit.
      09-28-2014, 07:50 AM   #34
movemnt Inc
Drives: 2012 F10 M5
hi andy, care to share where you got the cats done? I'm thinking of doing it to my car. no cel lights etc?
