      04-25-2011, 08:50 PM   #1
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
Thumbs up //APEX\\ ARC-8 Light Weight Track Wheels 18x8.5/18x9.5 1 series specific
APEX ARC-8 Light Weight 18" Track Wheels - 1 Series Specific Sizes
By Aftermarket Performance EXpress - ApexRaceParts.com
IN-STOCK & READY TO SHIP TODAY IN ALL 4 FINISHES!
CLICK HERE TO ORDER
Run 265 or 275 Rear tires with ease. NO fender modifications!
Fit up to a 255 Front tire with camber plates
Extremely light, and clears all Big Brake Kits
Squared or Staggered options available
Specifications:
18x8.5" (ET45) 18.10lbs $289
18x9.5" (ET62) 18.20lbs $314
1 Series Fitment
Wide Square and Staggered Fitment Options Available
18x8.5" ET45
This offset was designed specifically for the 1 series to properly fit a 1" wider wheel and meaty rubber up front
This wheel can be used on it's own on all 4 corners as a square setup or as the front wheels of a staggered setup
This wheel will accept 235/40/18 tires without fender or strut tube rubbing on a stock or lowered 1 series
245/35/18 or 255/35/18 tires can be used when combined with camber plates.
Some extreme summer and r-compound tires may require a 3-5mm spacer for proper strut tube clearance
Fender rolling and trimming of the bumper tab may be required with wide 255/35/18 tires
18x9.5" et62
The secret weapon for massive rear grip
This wheel allows for the fitment of 265/35/18 and 275/35/18 street tires with zero rubbing in the rear
Your car can be stock or lowered, these wheels will fit with wide rubber
Their unique offset takes full advantage of the rear room available and keeps the tire from touching the fender
3 series offsets do NOT work on the 1 series unless you want to run rubber band
This specialty offset is needed to run a wide rear tire, not just a wide rear wheel
What works and what doesn't
Camber plates are a must for anything wider than 235/40/18 up front
All 265 and 275 street tires work on the rear - but not all r-compounds do
We DO NOT guarantee that anything will fit. Not all tires are made the same and other modifications can effect fitment
There are numerous threads on this forum the show what's already been done
We recommend reviewing those threads or consulting with us to fully understand this specialty fitment
You can contact us directly for feedback on your specific application
Wheel Details:
Manufacturing process:
All APEX wheels are flow-formed resulting in a light weight, track and street worthy wheel.
Flow-forming significantly reduces weight in the barrel by rolling the barrel out into it's final shape using large wheels/disks applying high pressure.
This step is the same step that monoblock forged wheels go through to shape their barrels.
By doing this, the flow-formed wheel's barrel has the same density and strength as a traditional forged wheel.
This significantly reduces rotational mass at the furthest point from the center, which is the most important weight savings area on a wheel.
Strength:
These wheels are fully VIA and JWL certified with a load rating of 1550lbs.
Don't be fooled by competitors that claim to be certified, but cannot provide registration numbers.
There are vendors on this forum selling wheels that are not certified, yet they claim they are.
Finish:
The wheels will be available in 4 finishes
Hyper Silver
Hyperblack
Anthracite
Satin Black
Misc.
Comes with carbon-look APEX center caps
Accepts OEM Roundel center caps
Install using your factory lugs or a stud conversion
Accepts wheel spacers including 5mm thickness, while remaining hub-centric
TPMS compatible
Hyper Silver
Hyper Black
Anthracite
Satin Black
      04-26-2011, 07:45 AM   #2
Rafax28
Rafax28's Avatar
Mexico
Drives: M3 E92
Few days ago I bought a PS2 in 225/255. I know the goal with Arc-8 is to use wide tires, but I want to know how will works your wheels with my PS2?
      04-26-2011, 08:16 AM   #3
Bdh821
Drives: 2021 M550i
I'm getting my pilot super sports 235/275s mounted as we speak on arc8s. I'll let you know
      04-26-2011, 11:22 AM   #4
Roshi
Drives: 2015 M235 - MW, 6MT.
Wheels work great with PS2s. I am running 235/40 (F) and 265/35 (R) PS2s.
      04-26-2011, 11:45 AM   #5
premedsoccergod
premedsoccergod's Avatar
14
Drives: 135
is there going to be a group buy anytime soon?
      04-26-2011, 02:33 PM   #6
Eddy@ApexWheels
445
225/255 has been done by a number of people. it's a bit stretched since PS2's aren't a wide tire. But it will work. I'd just go wider once the PS2's are used up.
Not any time soon. At the end of the year maybe. Otherwise, only Jan-Feb of next year.
      04-26-2011, 02:49 PM   #7
lavmugen
Taiwan
18
Drives: 2011 Superman 135i
is this a special price or regular price?
      04-26-2011, 02:55 PM   #8
Eddy@ApexWheels
445
This is the regular price. These wheels are in stock and ready to ship. Special pricing is only offered on pre-orders for new sizes or some other form of pre-production order where payment is made months prior to receipt of product.
These can ship same day.
      04-26-2011, 06:17 PM   #9
Rafax28
Rafax28's Avatar
Mexico
Drives: M3 E92
Thanks. I think my tires are a bit stretched for the Arc-8, so it is that I asked the question.
      04-26-2011, 08:39 PM   #10
fancyfl1ght
fancyfl1ght's Avatar
Drives: 2016 BMW 228i
Me Too! Super Wheels. You can't go wrong.
Get'em. You won't be sorry.
Alpine White BMW 228i (Stripper Special with Lighting Package as the ONLY option), HD-LINK IW06B-N23 Backup Camera & HDMI Input, Technic ASD Removal Harness (Wire Nut Mod), Technic Hifi Harness, Focal FDP 6.900, Hertz Energy ECX 100.5.
      04-27-2011, 03:36 AM   #11
Oofie
Drives: 13 FR-S
Do these come in 17s? If they do, what are the biggest tires can I run on a completely stock car? Looking to replace my Kosei 17x8.5 et40 which can only run 235s all around without modification.
      04-27-2011, 01:05 PM   #12
Eddy@ApexWheels
445
These do not come in 17's. We only offer a 17x8.5" et40 which would cause the same issue.
      04-28-2011, 08:05 PM   #13
Eddy@ApexWheels
445
In stock and ready to ship. Please feel free to contact us if you have any questions about what size tires to run, how these wheels will work with your suspensions, and so on. We're here to provide advice. We're not interested in selling you something that won't work right, so if these aren't the right choice for you, we'll let you know.
      04-28-2011, 11:24 PM   #14
jeremydgreat
jeremydgreat's Avatar
Drives: 2009 135i
I just want to chime in and say- these wheels are amazing. I run 275's in the back and 255's up front (very light fender roll on all 4 fenders). I'm also lowered on coilovers. As long as your car isn't slammed and you have some 5mm spacers in the rear, you can rock massive tires.
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
      05-02-2011, 02:10 PM   #15
Eddy@ApexWheels
445
Thanks for the great feedback.
      05-04-2011, 02:41 PM   #16
Eddy@ApexWheels
445
These are ready to ship!
      05-06-2011, 02:03 PM   #17
Eddy@ApexWheels
445
All finishes are good in stock and we have more arriving in July
      05-06-2011, 09:35 PM   #18
C4747Z
C4747Z's Avatar
Drives: VO 1M & M5 Competition
Do you have anymore pics of the wheels?
      05-06-2011, 10:40 PM   #19
Roshi
http://www.1addicts.com/forums/showt...highlight=apex
      05-06-2011, 11:37 PM   #20
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
Hyper Black
Inner Strut tube clearance with no wheel spacer in front
My setup on these tires is 255/275 PSS. Vorshlaq camber plates up front.
Wheels rub in max turn on the inside of the wheel-well. Had to dremel out the bumper to front quarter flashing. No rubbing on the outside
No fender rolling.
      05-07-2011, 09:03 PM   #21
C4747Z
C4747Z's Avatar
they look great!
      05-10-2011, 09:43 PM   #22
Eddy@ApexWheels
445
Thanks for posting pics guys. These are still in stock and ready to ship. An international customer will be placing a major order for these wheels shortly (40+ sets for the 1 series). We have more wheels in bound this summer, but be sure to get these while they're still available in all 4 finishes.
Tags
245/35/18, 255/35/18, apex, arc-8, wheels
1addicts
