05-21-2018, 06:49 AM | #1 |
Rep 3,071
Replaced Cabin Filter easy job
It was an awkward but easy job.
1. Unscrew (20mm torx) two bolts holding under glove box tray, remove small screw holding carpet pad running along side console. Pull out tray. 2. Undue 4 screws holding bottom of filterr box, remove rubber hose on left, pull out two filters. 3. Mine were 3 years/37k miles old. One had air flow to engine, one to interior. 4. Install new filters, with air flow towards interior. 5. Breath clean air again.
11-27-2019, 05:58 PM | #2 |
Chieftain
52
Rep 274
Drives: E90 N54 335i
Cabin Air Filter
Hey do you recall the model # for the cabin air filter for your 6 series? Saw your post and am planning to change mine.
Got Boost? 2014 650xi F06 - Carbon Black 2015 640i F13 - Alpine White 2007 335i E90 JB4/HPF Gen 2 - Jet Black-Retired |
11-28-2019, 03:44 PM | #3 | |
Rep 7,470
There are two types...there's the filters that have activated charcoal (helps eliminate odors) and there's just the plain particulate filters...you can select/shop for whichever type you want for your personal application. Once you have the 11 digit BMW part number...then just shop using that number (i.e. Type BMW xx xx x xxx xxx into a internet/google search box).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-28-2019 at 04:17 PM.. |
Tags |
cabin filter |
