      01-12-2016, 05:58 PM   #1
DualMTurbo
Drives: 328i Msport
Wheel spacer recommendation please
Just traded in my beautiful Estoril blue 328i Msport (memories ?) for the new love of my life 650i Msport but I don't like way the wheels look sunk into the car.
I don't have plans on wheels at this time so what brand/size spacers would you guys recommend to get the wheels flush?
      01-14-2016, 02:19 PM   #2
Zack G.
Extraordinaire
Zack G.'s Avatar
Drives: '14 650i MSport CP
Congrats...I would say 10mm for your fronts and 12mm for your rears.
If you want a more aggressive look, maybe 12mm front, and 15mm rear.
      01-14-2016, 03:03 PM   #3
speedracerlo
Drives: 2015 M6 Gran Coupe
I got 10mm all around.
      01-14-2016, 04:15 PM   #4
AstonMartian777
Drives: 2014 M6 F06
15 rear 10 front.
      01-14-2016, 06:16 PM   #5
DualMTurbo
Drives: 328i Msport
Can you post up pics?
      01-14-2016, 11:38 PM   #6
Scott@Radar-Mirror.com
Scott@Radar-Mirror.com's Avatar
75
Drives: 2016 BMW 550i
I have run spacers on a few BMW's with mixed results. I had spacers on my new M5 and the steering wheel vibrated like crazy above 90 mph and had to take them off. Hope you have better luck.
      01-15-2016, 12:10 AM   #7
DualMTurbo
Drives: 328i Msport
I wonder why you got those results? I've run spacers in few of my 240sx projects back in the day and never had anything like that happen. Not saying it couldn't happen but I wonder what could cause that?
Were you running spacers with aftermarket wheels, coilovers and/or any other upgrades? I surely don't want those results since it would defeat the purpose of the ride quality bmw is known for.
      01-15-2016, 10:22 AM   #8
speedracerlo
Here's a recent photo taken by my SA at McKenna BMW
I have the KW HAS kit installed too
I need a car wash so I haven't taken any nice photos yet
      01-15-2016, 01:19 PM   #9
murph914
murph914's Avatar
66
Drives: 2014 650i Convertible
Don't ///M cars have different suspensions and wheels and offsets? I would think the pacer thickness would be different for an m car vs a 640 or 650. That said, what manufacturers are prefered for spacers?
      01-15-2016, 05:07 PM   #10
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Yes M Cars have completely different suspensions, wheels and offsets; however you can install M5 wheels on any 6 series with no issue. M6 wheels are 0.5" wider than M5 wheels with different offsets so basically you will have rubbing issue on rear wheels if you install M6 wheels on your 6 series.
As far as offset the major issue is the rear wheels. Regular 6 er M sport wheels(373) have 44mm offset on rear wheels which is 10 mm less than M5 wheels (i.e. 343M - M5) and 25 mm less than M6 wheels (i.e. 343M - M6)
For front wheel there is no major issue since 373 has 33mm, 343m -M5 has 33 mm and 343M M6 has 32 mm; however they all have different width...
      01-15-2016, 05:23 PM   #11
Giggity
Drives: 997.2 GT3RS, Audi SQ5
M6-Coupe, Are you running spacers on your M6 with the OEM wheels? Sizes?
Anyone else running spacers on an M6 with OEM?
      01-15-2016, 05:48 PM   #12
rma206
Drives: M6 gran coupe
I just put on eibach 25mm spacers for my winter wheels - 343m 19. Could have realistically gone to 30mm!
      01-15-2016, 05:57 PM   #13
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
No I'm not running any spacer but I have 305/30/20 tire installed on rear which is equal to 5mm spacer anyways...
I believe you can run 10-15 mm spacer all around M6 with OEM wheels...
      01-20-2016, 10:23 PM   #14
75
I have Dinan springs, everything else is stock. I had spacers on my E60 M5 with no issues but no luck on my F10. Kind of sucks, I hate the look without the spacers.
      01-27-2016, 04:19 PM   #15
speedracerlo
It's probably because you didn't have Hub Centric spacers. They need to be minimum of 10mm to be hub centric. Otherwise there will be vibrations.
      01-29-2016, 06:53 AM   #16
LI M6
Drives: 2014 M6 GC
I'm running OEM wheels and tires with 12mm spacers in the rear and 10mm in the front.
Car is lowered 3/4" on Dinan springs.
      01-29-2016, 11:17 AM   #17
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
I'm wanting to go with 10mm all around with a 305/30/20 tire on the rear anyone see any problems with that on factory 601's
      01-31-2016, 11:11 AM   #18
speedracerlo
if it isn't lowered, then 305 with 10mm spacers should be fine. it may rub if lowered though.
      01-31-2016, 12:43 PM   #19
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
Ok thanks!
      01-31-2016, 10:53 PM   #20
75
My car had 10mm/12mm hub centric spacers from Macht Schnell. I even swapped them front to back a couple of times and no luck either way. I guess I could try another brand but have a feeling it won't matter.
      02-06-2016, 01:07 PM   #21
speedracerlo
Hmm that's very odd. I have the Macht Schnell 10mm front and back. No vibrations at any speeds.
      03-04-2016, 06:30 AM   #22
msginnie
RS Technik spacers 15 mm are best.
