      01-21-2014, 12:37 PM   #1
Apr1962
Drives: 640D
Door panel removal on F13
I need to remove my drivers side door panel.
I have looked on the web, but can't find any pictures, instructions or videos.
Does anyone have any instruction or pictures they could post.
Many thanks
Andrew
      01-21-2014, 03:34 PM   #2
Palmnuts
Palmnuts's Avatar
170
Drives: Huracan Evo & M8 GC
Yes, dead easy - and for the record, none of the visible trim comes off to remove the door panel as it's all attached from the back.
One screw (just the one!) in the air vent duct (you see it when the door is open).
Then, using a trim removal tool or similar and starting in the region where you removed the screw, start popping the trim away from the door all around the edge, trying not to break the clips (they are VERY strong so you shouldn't break any).
Then pop the door away along the top where it meets the window - there's about 4 to 5 sections where it clips into the metal along the top and these pop out like the rest of the door.
The final bit is the most tricky - the middle of the trim is held on by two more very strong push-in clips just behind the door pull. Gently rock the door trim from side to side whilst pulling on it and the trim will free itself. If you can get your hand in there to apply some pressure close to the clip then it'll be even easier.
Now, if you get this far can you do me a favour please and take a picture of how the mid-range speaker is plugged in? My speaker has two different terminals that the wire can attach to and I failed to check which one it was before I pulled it off! I have chosen one of them and it all seems fine (theres a 50% chance I got it right) but the OCD in me wants to be 100% sure I got it right! I assume using the wrong terminal puts that speaker out of phase, although I can't say I can tell.
jjasonSU194.00
      01-21-2014, 03:48 PM   #3
Apr1962
Drives: 640D
Brilliant. Thanks.
When I take mine off I'll leu you know.
      03-15-2021, 03:26 PM   #4
Lawrence2K
Lawrence2K's Avatar
Drives: BMW 2016 650i
Removing passenger side door panel
Sorry to bring up a hold thread, but would you know how to remove the passenger side, removed all the pin, but there is still one thing holding in to it, when I removed all the pins on the driver side, it came off completely, but for the passengers side, there is still something holding in to it
      08-23-2021, 05:20 PM   #5
Dinan M6
Drives: BMW M6
2013 M6  [10.00]
There are two screws on that side...one in the top handle and one in the vent.
      01-13-2022, 11:39 AM   #6
Lindley
Drives: BMW M6
I’m having some trouble myself with the passenger side door panel. The clips around the edge are loose, The big single clip in the center is free, and the screw in vent and has been loosened, but something else is still holding it up.
Any further details?
Picture of door panel attached. Thanks!
      01-13-2022, 12:03 PM   #7
Lindley
Drives: BMW M6
Ahhh ha!!
Found that tricky missing second screw beneath the diagonal door handle.
Here’s a pic in case anybody needs one in the future.
