      04-15-2017, 02:25 AM   #23
Downfourit
Drives: M6 Gran Coupe`
Originally Posted by speedracerlo View Post
Not true, I'm running 10mm front 10mm rear. There may have been some updates to 2016 models as my X6 has this issue. 2015 X6 does not have the longer hub that sticks out.
It is however true that anything less than 10mm is not hubcentric and will cause vibrations.
Yeah they probably changed something for 16 cause I picked up a 12mm for the front and 15mm for the rear. The fronts worked with the 15mm but not the 12mm, so I just stuck the 12mm in the back and left the front alone.
      04-18-2017, 03:35 PM   #24
Acexxon
Drives: 2016 F06 M6 F87 M2
Question, with a rear spacer, how will it affect cornering performance? If at all?
      04-27-2017, 10:43 AM   #25
Eurohorses
Eurohorses's Avatar
503
Drives: 23 Jahre G80 M3
It doesn't... if anything, it provides a slight wider track for the car and that results in more stability. In my opinion, its all aesthetics... can beat a car with flush wheel and tire setup
      04-28-2017, 05:38 AM   #26
Niklas
Niklas's Avatar
9
Drives: San Marino M6
i think this is the right place to post this question, what mm lower springs and spacers do i go for on my m6 coupe if i want that flush look and low wide stance? I have the standard 295 tires.
Thanks!
      04-28-2017, 07:19 PM   #27
His4
His4's Avatar
37
Drives: F13 M6
Thanks!
25/25mm lowring springs
12/12mm front & rear spacers
      05-03-2017, 06:21 AM   #28
IM6
Drives: BMW M6 F13
Originally Posted by Downfourit View Post
I'm with M6, just run rear spacers if anything and wider tires up front and rear. If it rubs just remove the rear spacers. Any time I have run spacers on the front I notice a new shake or vibration in the steering wheel.
that's true, I have vibration with 10mm spacers at the front.
      05-03-2017, 05:08 PM   #29
His4
His4's Avatar
37
Drives: F13 M6
Yes at me too, between 120kp/h - 150kp/h
Than i clean the wheel hub thoroughly, and now there is no vibration anymore
      05-10-2017, 08:02 PM   #30
splking
Drives: F82 M4
For those looking to add spacers to their car... i've just put 15mm spacers all round on my F13 M6 comp and can report no adverse wheel wobbles or shaking... can't comment on the handling at the mo as I've not really pushed it hard yet, but it seems fine... I've not noticed the difference.
Pics below...
In the process...
The side that has NO SPACERS!
Side WITH SPACERS!
H
      05-12-2017, 07:34 AM   #31
IM6
Drives: BMW M6 F13
Splking ive got exactly the same colour, my vibration persist between 100 - 106 MPH
      05-12-2017, 08:30 PM   #32
splking
Drives: F82 M4
Interesting, do you have the same size spacers, 15mm front and back? I am using Bimmec hub-centric spacers which are supposed to be a quality item. I've driven the car at various speeds and can't say I've noticed a vibration... do you have it at lower speeds too (like 50-53mph for example)?
H
