      05-16-2014, 12:37 AM   #1
RespectTheGC
RespectTheGC's Avatar
Drives: 2014 BMW 640xi GC
Front Drivers side window keeps rolling back down
Front Drivers side window keeps rolling back down after reaching half way closed on 1 touch up. Pinch protection issue? Car is tinted if that matters. All other windows work with no issues.
      05-16-2014, 11:11 AM   #2
RiverRunner
RiverRunner's Avatar
Drives: 2014 M6 Gran Coupe
I noticed that mine will do that if the window is moving while turning off the ignition. Also if the door is open.
2015 740i Sapphire Blk/Blk
2018 Tahoe RST 6.2
2019 Porsche 911 Turbo 991.2
      05-17-2014, 07:57 AM   #3
doug_999
doug_999's Avatar
2543
Drives: 2011 1M/2021 992/2023 X3
There is a reset procedure you can try - search google as I'm not sure if it is specific per BMW.
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      07-09-2014, 02:12 PM   #4
ctenidae
Drives: 2012 650i Coupe- Manual
Mine's doing that. At the service center now, with that as one of several issues. For a car with only 16K miles, this thing has been in the shop a lot, even accounting for all the times they keep screwing up my driver's seat (which I count as a service issue, not a car quality issue).
      07-10-2014, 10:04 PM   #5
Krash7172
Drives: 2018 530e, 2020 X4
I had the pinch protection issue on several BMWs. Each time it has been friction from the weather stripping. I leave my windows down a lot and evidently the weather stripping can change shape a bit. I had this problem with my sun roof on my 6. Holding the button overrides the pinch protection. Have you tried that with a 6 window?
      07-11-2014, 12:36 PM   #6
ctenidae
Holding the button up keeps it from rolling itself back down, but you have to release it and then lift it again. And sometimes it still goes back down by itself.
Having to hold the button kind of reduces the usefulness of auto up, I'd say.
      07-11-2014, 01:11 PM   #7
Krash7172
Once I got mine closed, it squashed the weather stripping back in to shape and fixed it. Anything else probably needs dealer attention.
      07-11-2014, 05:16 PM   #8
Bönz
Bönz's Avatar
Drives: 2018 M5
try rolling it down with one touch. then after it stops, push the button down and hold it for about 5~10 seconds. you may notice the wind going a bit further down. then try one touch up. this process might reset it.
