11-14-2015, 11:52 PM | #23 |
Rep 592
It's in a completely different format, DIN. If it was SAE, or STD we could compare, also in DIN vs. STD it would be a reduction in HP on the DIN side. So his supposed 614CHP converted to whp @ 534whp would be more like 460whp or something close. Funny thing is, he is on a dyno and could post the whp figures but chooses not to
11-16-2015, 12:31 PM | #25 |
Rep 592
Just stop.. That dyno is making no sense. So now you are making 516whp DIN corrected which is like 500whp in STD/SAE here in the states, then it says you're making 711wtq?? The cars' tuning must be garbage to have the numbers so far apart. Plus on the 1/4 mile or racing if that number were correct you would have zero traction, you would blow out your trans and rear end.. Good luck with your car, I would never be a guinea pig on a $100k car.
11-16-2015, 12:45 PM | #26 | |
Rep 6,067
11-16-2015, 01:06 PM | #27 |
Rep 6,067
I'm not trying to break your palace but 0-100 km/h in 3.2 second with this heavy RWD and front weight bias car? even if you have enough power/torque it is not possible because of traction. For your information I have 305/30/20 Nitto N05 semi slick tire and the best 0-100 km I have got with my M6 is 3.7 second.
To reach that number you need a lot more power and torque + either AWD car or rear weight bias car... FYR mid engine Ferrari 458 with 570 HP and 3400 lb , ~45/55 weight distribution can reach this number! which tire are you running on?
