10-21-2015, 02:38 AM | #1 |
BMW Enthusiast
Rep 71
Dinan Stage 1 ECU Tune (N63tu Engine)
Hi, I recently had a Dinan Tune (Stage 1) done by EAS. Below is the picture of the result.
Stock was around 380 whp. Putting out 452 hp to the wheels with the tune. What would be this be equivalent to in crank HPs? Anyone else mind sharing what their 650i is pulling? Thanks!
14' 650i Coupe.
Alpine White M-Sport Package Dinan Stage 1 H&R Lowering Kit Last edited by BBLF13; 10-21-2015 at 02:39 AM.. Reason: adding info |
10-21-2015, 02:07 PM | #2 | |
Rep 3,128
The most common formula for calculating wheel to crank horsepower is adding in a 15% drivetrain loss factor but that's a very simplified approach. We typically use a PEAK 12-13% drivetrain loss on the late model cars but that varies by gear, rpm, transmission, etc. For simplicity a flat percentage is what is commonly done. Taking your low HP run that would equate to (using a 13% drivetrain loss): 444 WHP x 1.13 = 501.72 at the crank (506 advertised) 480 WTQ x 1.13 = 542.4 at the crank (547 advertised) That said your stock numbers were lower than ours (380 WHP x 1.13 = 429.4 at the crank where we saw 446 at the crank with our test vehicle) so you actually gained a bigger delta then what we advertise. Not to mention I assume you were running 91 octane fuel being in California whereas we report using 93 octane so possibly an even larger delta then that. |
10-21-2015, 07:10 PM | #3 | |
Rep 592
10-21-2015, 08:20 PM | #4 |
Rep 18,713
@BBLF13 , my 650GC baseline was 397whp.
It was done at EAS also.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
10-22-2015, 08:41 AM | #5 | |
Rep 3,128
Steve Dinan: Hi Joseph, We recently saw your post regarding our new Turbotronics project and wanted to clarify a few points to make sure your readers have the correct information. I stand by my comments on "Tech tip Tuesday". Even though we are making an ECU we are still believe software has superior performance and reliability when compared to an ad on ECU. Having said that the new Bosch ECU has proven more difficult to crack than previous models so we have been forced to go the ECU route. BTW this is Dinan's 16th Turbotronics ECU because we used to make them a long time ago but when we got very good at software we went away from them because of the obvious advantages. “Tech Tip Tuesday” was also referring to the existing piggy back boxes on the market. Our goal wasn’t to imply that a piggyback box wasn’t a viable tuning solution, but rather the current ones lack sophistication in which is why they make less power, have more drivability issues, are more prone to setting faults and are not emissions legal. I also mentioned that a box would have to be much more sophisticated in order to work properly and not risk any damage or malfunctions with the vehicle long-term. The reason our software is more expensive than current piggyback systems on the market is the level of work and research that is required to “crack” BMW’s factory computers, the additional cost of the 4 year 50k mile warranty and emissions certification. The cost our R&D, warranty and emission testing when compared to manufacturing the piggy back boxes I see on the market it is more likely they are making more money than Dinan soit is not about money as the person implied it's about doing it right. Most people assume that BMW gives us complete access to the computers, but that is not the case. We have a team of 5 engineers that do nothing but read through every line of code on each ECU to make sure that all of our software allows the car to function properly, doesn’t interfere with other electronics and keeps factory system safeguards in place. As far as the new “Turbotronics” units are concerned, (still in development) they essentially are more than a piggy back box they are a powerful ECU that has many more capabilities that the existing piggy back boxes. To help you understanding the additional capabilities as I said in "TECH TIP Tuesday" the existing boxes send a an adjusted signal to the BMWECU telling it he boost is too low and the ECU then raises the boost to what it thinks is the correct value as does ours. This false value creates errors in Fuel mixture and ignition timing. This can causesmore faults, high catalyst inlet temperatures and a loss of power.In addition when you increase power exhaust temperature will increaseand this must be countered with a slightly richer mixture. Our ECU will have the capability of setting a richer target lambda (fuel mixture) as well as correcting short term trip which is the difference between target and scheduled fuel mixture just to mention a couple of it's capabilities. By matching these two correctly we can reduce knock sensor activity which will make smother performance,protect the catalyst, increase power and allow us to make it emissions legal. We have a lot of exciting new product in the works for N55 powered cars along with products being created for the M235i. Keep an eye on our social media channels for announcements on sales, new products and more of our Tech Tip Tuesday series. Thanks again for your time and we hope this is helpful. If you’re interested, we would love to have you out to the facility to see our operation first hand. Sincerely, Steve Dinan |
10-22-2015, 01:31 PM | #6 | |
Rep 80
Drives: 2012 BMW 650I Coupe Imola Red
What is confusing for me is I have a 12' 650i.. so N63. Is the N63 still a flash tune? or is there a piggy for N63's now too? On Dinan's site there is no mention of Dinatronic Also does anyone know why N63 550 stock dyno's have been anywhere from 380-395whp? I though N63TU was a 45HP boost |
10-22-2015, 01:59 PM | #7 | |
Rep 592
10-22-2015, 02:19 PM | #8 | |
Rep 80
Makes sense..I am thinking in my head that the graphs would still average much lower for N63's... by a larger amount. Instead its been almost the opposite..so many N63 (550's) mostly have baselines that seem higher than the average TU's...I admit not as many TU graphs around.. for a comparison. Wonder how valvetronic helps? I am actually glad I dont have valvetronic..as I have had a variety of Bimmers with it and had all sorts of valvetrain noise ticks failures..etc. I checked all over..seems there is no Dinantronic for n63 |
10-22-2015, 02:55 PM | #9 |
Rep 3,128
N63 (non-TU) cars were the last of the software tuned cars so no, there is no piggyback for those vehicles as software could still be applied from Dinan. The TU motors switched ECU's in the process as well going from the Siemens ECU to a Bosch one on the TU motors. The newer Bosch ECU has encryption (NSA level) that essentially makes traditional software tuning impossible without physically bypassing the encryption by opening/drilling into the DME so the DINANTRONICS were born because of that.
10-22-2015, 03:18 PM | #10 | |
BMW Enthusiast
Rep 71
dyno
On that note, does weather really makes a huge difference with power output? And yes it was running 91 Octane. I wanna try to dyno the car again with race gas (100 octane). How much power should i be expecting? Dinan_Engineering
14' 650i Coupe.
Alpine White M-Sport Package Dinan Stage 1 H&R Lowering Kit |
10-22-2015, 03:21 PM | #11 | ||
Rep 18,713
The humidity play a big factor also.
10-22-2015, 03:53 PM | #12 | |
Rep 80
10-22-2015, 04:14 PM | #13 | |
Rep 3,128
10-22-2015, 11:33 PM | #14 |
BMW Enthusiast
Rep 71
Dinan_Engineering Thanks!!!! Looking forward to get the tune with the race gas. I will post it up when I do.
I'm considering the stage 2. Will it be much of a difference comparing from stock to stage 1? Thanks again!!
14' 650i Coupe.
11-13-2015, 04:27 AM | #16 |
Rep 592
I'd like to see those numbers on a Dynojet here in the states, I have a feeling that old Moscow mule (dyno) is producing inflated numbers from outer space! Plus the graph is saying crank horsepower and NM for torque.. Show us a real wheel horsepower graph!
11-13-2015, 05:49 PM | #19 |
Rep 592
The fact that the dyno is reading crank horsepower shows the amount of BS you are posting is ridiculous. It's on a dyno, what's the problem with it showing wheel horsepower like every other dyno on earth? Somehow you magically unlocked the NSA level encryption on the BMW ECU? You would be the only one, again very hard to believe. Then again this is Russia, no truth comes out of that place
11-14-2015, 01:49 PM | #21 | |
Rep 592
11-14-2015, 11:29 PM | #22 | ||
BMW Enthusiast
Rep 71
Based on mathematical calculation 614 CHP x 0.87 (13% drivetrain loss) = 534.16 WHP.
14' 650i Coupe.
