      10-26-2015, 09:19 PM   #45
terrainx
Drives: bmw
Good to hear... I'm wondering if BMW may have fixed this in later model years but to know we would need a large/larger sample.
Originally Posted by kris1858 View Post
Haven't had any issues with squeaking seats on my '16.
      10-26-2015, 11:02 PM   #46
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Indeed... I do know there were a bunch of internal tweaks done to the car with the LCI. (One being changing the type of connectors on the interior lights.)
      10-31-2015, 04:02 PM   #47
Bellagio
Drives: BMW 320D
I have a 320D and have finally managed to get rid of my seat creak/squeak after years of annoyance so hopefully it might help someone or worth a try if your vehicle suffers from the same creaking. Mine sounded like a metallic kind of creak, like a spring creaking. It happens if I pushed my lower back into the seat and no matter what position I put the seat in it would still do this annoying creak. I've tried everything from tightening nuts to trying to spray WD40 into the side parts of the seat, underneath and in the gap in the leather up inside the back of the seat but with no success. My car is a UK 320D Right Hand Drive with manual leather sports seats. This is my solution: Raise your seat as high as it will go and push it as far back as it will go. Then look under the front of your seat (kneeling down outside the car). Where the manual TILT control (not the height lever) lever is (front of seat) you will see it connects to a small spring. This spring has a little bit of thin black plastic wrapping around it. Mine had moved to the front so I checked my passenger seat (which doesn't creak) and that one had the plastic wrapper pushed to the back so I did the same to my driver spring wrapper and the noise has gone! There is also a metal rod that goes from just behind this spring across to the other side of the seat (still underneath the seat). This kind of moves a little so I just made sure it was in the same position as the other (passenger side) and again the metallic creak has finally gone!!! I've adjusted the seat and still no creaking! The funny thing was the creak always seems to have sounded like it was coming from the lower back area of the seat but it must've been coming from this little spring all along. As said before it's attached to the lever that operates the tilt. I've also cleared annoying sounds from my cabin heater/blower by removing the micro filter and spraying (tons) of WD40 into the heated (rusted nut looking part in the centre), this took a few goes but used to drive me nuts every time I braked it would sound like trapped leaves stuck in there spinning on certain fan speeds. The other major annoyance was door rattling, I spent years lubricating the rubber door seals with Gummi Pflege but only this year have realised it's not coming from the rubber seals but the felt/nature strip (not sure of its official name) which goes around the outer edge of the inside of the door (looks like black felt even closer to the edge of the doors than the rubber seals are) and after using Gummi Pflege on that they are now silent. Hope this helps someone as have been searching for years and finally have a squeak/creak free car!
      03-08-2016, 09:21 PM   #48
MMMMK
Drives: M6 GC
I just picked up my new 16's yesterday, and the driver's seat starts to squeak now. so disappointed.
      03-09-2016, 09:39 PM   #49
m5sdse63
Drives: 2014 M6GC CP
I also have noticed the creaking/squeaking noise from the bottom of the driver's seat but only when I'm turning, and not all the time. I am neither tall nor heavy so I don't think my frame is to blame...
Garage:
2014 M6
2015 i3
      03-14-2016, 04:31 PM   #50
TT BT
The cars we drive say a lot about us.
TT BT's Avatar
49
Drives: 2020 BMW M850i
this is happening to me as well. My car was at the dealership 4 times for the same problem and they found some piece of metal from the frame broken and rubbing on the rails causing the noise. They changed the bottom frame and padding and now is making noise only when turning. BMW didn't want to change the seat cause they couldn't duplicate the noise . Of course you can't duplicate the noise if the car is seating at the dealership
anybody had a similar experience ?
A bad day at the Racetrack beats a good day at the office
      03-16-2016, 06:52 PM   #51
terrainx
Drives: bmw
How many miles do you have on your 2016?
      03-16-2016, 08:18 PM   #52
MMMMK
Drives: M6 GC
It was 200km but the problem is gone after I adjusted the seat position. It was actually two pieces of leather rubbing against each other, hope it won't come out in the future:
Tags
seat, squeaking
