      04-04-2024, 05:20 AM   #23
Frank Duncan
Drives: 2016 BMW 640i convertible
Originally Posted by Qsilver7 View Post
…glad you got it sorted out and thanks for updating the thread with a verifiable solution.
Hello
I have the same problem and am very interested in how the boot can be opened via the fuse box. Can anyone explain the procedure please?
      04-05-2024, 02:37 AM   #24
Qsilver7
Qsilver7's Avatar
Originally Posted by Frank Duncan View Post
Hello
Have you tried connecting a power source to the jump start terminals in the engine bay yet…then using the interior trunk release button or the unlock button on your remote fob?
I would try to use the easiest method first (power to the jump start terminals)…then move on to more difficult method.
      04-05-2024, 02:43 AM   #25
Frank Duncan
Thank you for your help but I’m afraid that I have inadvertently complicated things. When I removed the battery for charging I separated the two parts connected to the positive terminal. I am now considering if I could enter the boot through what would be the ski hatch. I have tried all the usual routes but even connecting the jump terminals doesn’t complete the circuit for the boot motor release.
      04-05-2024, 03:09 AM   #26
Qsilver7
Qsilver7's Avatar
Thank you for your help but … I separated the two parts connected to the positive terminal.
Oops…yes, that does complicate things when you separate the positive cable at the BST. It no longer connects the engine bay to the cars electrical system (front & rear fuses).
Hopefully you can reach the emergency release in the trunk. It’s located on the section where the pull down handles are…and the handle should “glow in the dark”…so shine a flashlight/torch into the trunk to help find it.
Good luck.
      04-05-2024, 03:14 AM   #27
Frank Duncan
Thank you again for your reply. I have one other possible solution. However I think it is tricky. The fuse box, behind the glove box, I believe has a connection that I can try putting 12v on with the chassis connected to earth. I can’t get to it currently as the car is outside and it is snowing! I’ll let you know how I get on. Cheers 🤞🏻
      04-15-2024, 12:17 PM   #28
Frank Duncan
Finally I managed to get the boot open by finding pin12 on a slide out connection box attached to the fuse box under the glovebox. Once put 12v on that pin with a good Earth too the boot motor popped the boot lid open.
If anyone has this issue I can help but it is involved and requires the removal of the glove box.
Bluefoz28.50
