08-16-2017, 03:06 PM | #1 |
Rep 425
Creaky Seats when cornering
Sprayed the whole underneath with PTFE and will see if that eliminates it but I'm not hopeful so may be booking it into the dealer under the BMW approved used warranty.
Anyone else experienced this? Last edited by Evil Derboy; 08-16-2017 at 05:04 PM.. |
08-17-2017, 06:00 AM | #3 |
Rep 156
08-17-2017, 04:07 PM | #4 | |
Rep 425
Put the seat position as high as it would go and literally used about half a can. First with the straw getting right up inside the side bolsters on the seat base. Then without the straw I sprayed everything underneath thoroughly from the underside of the seat, the runners, any nuts and bolts and all the plastics and bits underneath. Next I moved the seat forward and did the same thing from the rear. Then I put the seat back forward as you do to access the back and with the straw I sprayed into the gaps at the bottom and to the side where the seat back meets the base. Left it all for an hour or so and then did it again. Literally swamped the whole lot in PTFE. Cornering creak is now gone. |
gregmb19.50 |
08-19-2017, 06:51 AM | #5 |
Rep 3,071
If you have the seat all the way to the bottom it will squeak, try lifting a bit, that eliminated my squeaks
08-19-2017, 02:30 PM | #6 |
Rep 425
08-23-2017, 04:16 PM | #7 |
Motiphd
122
Rep 232
But doesn't your car now smell like a mechanic's shop?
2016 535i xDrive M-Sport | 2016 328 xDrive w/Lighting (hers)
2012 VW Jetta GLI 6MT APR Stage 2 (retired) | 2012 VW Tiguan SEL 4Motion (hers/retired) 2012 Acura TL SH-AWD Advance (retired) | 2012 Acura RDX Tech (hers/retired) 2010 Acura MDX SH-AWD Advance (hers/retired) |
08-23-2017, 04:59 PM | #8 |
Rep 425
