11-28-2014, 05:40 PM | #1 |
Rep 35
M5 343M 20" wheels for 640i XD GC?
I currently have 373m 20" wheels on my 2014 640i XD:
8.5 x 20, ET 33 9 x 20, ET 44 I want 2013 343M 20" wheels from the M5: 9 x 20, ET 32/34 (haven't figured out which of the 2 it is) 10 x 20, ET 34 Does anyone see any issues with this? According to what I have read, this should work |
11-29-2014, 11:13 AM | #3 | |
Picture me rollin'
307
Rep 1,130
12-01-2014, 11:44 AM | #4 |
Rep 35
12-02-2014, 01:18 AM | #5 |
Rep 7,034
Same from factory...just swap them from 373M...245 front and 275 rear..but you can easily go with 255 front and 285 rear...i will definitly go with my new tire setup..and NON RFT!!
11-10-2015, 04:04 PM | #6 | |
Rep 64
I ordered a competion M5 wheel at the dealer and they tried to fit it today. I had no time to check it out myself, but they called to let me know the rear sticks out to much. I told them that it's already been done fitting M5 wheels. Now I want to check it out myself in a few days, but a pic of your wheel straight from the back will help a lot to convince the dealer. Thanks |
11-10-2015, 08:57 PM | #7 | |
Picture me rollin'
307
Rep 1,130
11-11-2015, 02:57 AM | #9 |
Rep 64
That's what I thougt also, but they assured me they were the M5 versions. I neex to check the specs, but you're pic could be a good reference.
11-14-2015, 08:39 AM | #10 | |
Rep 64
Thanks, |
11-16-2015, 04:06 AM | #11 |
Rep 7,034
Sorry bro,i have changed to winter setup..but i garantee that it will fit perfect,if its setup for M5..dont worry..mine bmw service told me same,but they were wrong..cant wait to see pics.
11-16-2015, 03:25 PM | #12 |
Rep 55
Please let us know how this turns out. I'm looking to swap my 373M's for the 343M's on my 640i coupe but don't want to purchase them yet without knowing they truly fit.
11-16-2015, 03:55 PM | #13 |
Rep 6,064
As others said, the M5 rims fits perfectly. Just make sure you get M5 343M (20x9, 20x10) and not M6 343M (20x9.5, 20x10.5)
11-17-2015, 09:30 AM | #14 |
Rep 64
OK, just to let everyone know. It doesn't fit. It's not flush, unless you like this look. The outside of the rim is about 7mm wider than the body of the car without a tire. When fit a tire it will add another 2-5 mm.
Damn it looked so nice. Pics below. Last edited by Dennisr; 11-17-2015 at 09:48 AM.. |
02-24-2016, 10:53 PM | #15 |
Rep 842
With tyres on the wheel and the wheel taking full weight, would the camber not be enough to bring the wheel in enough to fit flush?
02-25-2016, 12:05 AM | #16 |
Royce Martin
56
Rep 572
You could run 285 on the rear so it can sit under the quater panel (if it's the OEM M5 Wheels). I'm currently running the M5 wheels on my 650i Gran Coupe.
04-20-2017, 03:12 PM | #17 |
Rep 147
Any problems with xdrive on this setup? The front wheel circumference is a bit different thn the rear I figure. Any issues?
Keysersoze81927.50 |
04-20-2017, 04:58 PM | #18 |
Rep 1,719
use 255/35/20 and 295/30/20 and the tires are the exact same diameter - perfect for xdrive
04-20-2017, 06:16 PM | #19 | |
Rep 264
Jamescc75: The only thing you should be aware of is that I am running 20x10.5's on the back. The 295's will be a little fatter on yours (sounds like you are looking at 20x10's for the back) but I still think that would be the right thing to go with. |
04-20-2017, 08:04 PM | #20 | |
Rep 1,719
The 295 on the 10 inch wheel is perfect. Beefy but not bulging over the rim. |
04-21-2017, 04:07 AM | #21 |
Rep 147
I am thinking about using 245/35/20 in the front and 275/30/20 in the back.
What tires do you use? I am thinking about putting on Michelin PS 4S but there are non with BMW *. Do you use BMW Approved tires or its just a matter of size ? |
04-21-2017, 07:03 AM | #22 |
Rep 1,719
Just size. As long as the load limits are in the same range you will be fine. I should note that the picture above with the rims sticking out past the fenders can't be M5 wheels. I would bet they are M6 wheels.
Get what you want, but a 275 tire on a 10" wheel is at the small end of what will work. Again, the 255/35 295/30 is the optimal fitment for the M5 wheels on an xdrive car. |
