      02-20-2014, 11:22 PM   #1
lzyla
Drives: 09' 320d, 12' 1 M
6GC X-drive wheels setup
Hello!
I am waiting for production of my 640 xd GC M-sport (placed an order already) and have a tough decision to make.
Originally the m-sport version could be equipped with the following wheels:
FRONT: 8,5 x20 ET33 - TIRES 245/35/20
REAR: 9X20 ET44 - TIRES 275/30/20
so it comes with staggered setup from factory.
I really like the look of the M5/M6 wheels and I would be happy to order mine with standard M-sport package 19" (to keep it for winter tires) and order the 20" M6 wheels for summer additionally.
My question is: Would that be fine to mess with the ET on xdrive ?
The RWD M5 wheels which i plan to order have :
FRONT: 9x20 ET32 - TIRES 265/35/20
REAR: 10x20 ET34 - TIRES 295/30/20
What do you think about such a wheels on xdrive version?
Would that cause any harm to the xdrive?
As far as I understand - the ET should have no influence on the rotation speed of the wheel? Would you recommend chossing different ET wheels (compared to factory's version) if i make sure that the rotation speeds are ok?
Would this ET difference have any influence on xdrive?
I'll be gratefull for your opinions.
Regards
Lukasz
      05-02-2014, 03:49 PM   #2
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Well,i have the same problem.
I want to install 433m wheels,but 20x10,5 ET 19 rear makes me nervous.
I winder will it fit correctly?!
Anyone?
      05-02-2014, 09:26 PM   #3
BOSTONbeemer
BOSTONbeemer's Avatar
Drives: 14' 650i GranCoupe M-pkg
Originally Posted by lzyla
Hello!
Regards
Lukasz
I used to think about all the variables with putting staggered wheels on my 650 xdrive, but then I just did it. 22x10.5 rear, and 22x9 front. 265/30/22 + 245/30/22. Yup if you look at the OD on both tires, the setup has about 1" taller in rear than front. I did this with 6 miles on the car, and I now have 10k miles. No issues, no problems what so ever. I drive her daily, even in the snow. If you had an R8 with the Quattro awd, or a gallardo id be more worried. The BMW awd system is not always locked like some other manufactures. You might not like what I did, but everyone is entitled to their opinion. Good luck!
      05-03-2014, 12:19 AM   #4
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Check this out:
http://www.6post.com/forums/showthread.php?t=968941
This guys has a 640i GC and installed the 433M whiles which are 0.5" wider than 343M you are talking about.
He claims that sometimes rear tires rub-off with the car underneath plastic stuff. Since 343M are narrower, you may be fine, but it's better to check with your dealer first. For sure they know better than us
      05-05-2014, 10:51 PM   #5
cleanGC
Drives: 2014 640i Gran Coupe Xdrive
Hello!
Regards
Lukasz
What suspension are you running? Looks good. I like the drop. I can't find any coilovers that is made for my 640ix F06.
2014 640i Xdrive Gran Coupe
      06-03-2014, 12:32 PM   #6
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Does 11" fit the rear? If so, match the wheel/tire specs from a Porsche Panamera Turbo S for the 20s. This is important b/c the rotational distance need to be the same for the front and rear on xDrive. The Panamera Turbo S has AWD (with 20s) so that should help get close to the correct setup. On setup, I would go with Forgestar or other custom wheels to ensure flush fitment and offset. I don't like messing with spacers.
I don't think you can use the RWD setup from the M5.
      06-06-2014, 09:38 AM   #7
JNoSol
JNoSol's Avatar
I confirmed that our cars do fit 11" rear. So the setup as follow - 20x9.5 in the front and 20x11 in the rear. Tire size is 255 35 20 front, 285 30 20.
A less aggressive setup is 20x9 front / 20x10.5 rear - Tire size 245 35 20 front / 285 30 20 rear. (this closer to what is needed for xDrive - front / rear is almost 0% error)
http://www.willtheyfit.com/index.php...et2=20#content
      11-19-2014, 01:59 AM   #8
Rakeford
Drives: Bmw 640d
I have 433 wheel ian fitting to my 640d but with 9.5j front and rear. Front has 255 tyres rear 285 tyres. Does anyone know if you need spacers on the front so the 9.5j wheels don't rub? If so 10 or 15mm. Anyone know if Aram who out the 433 wheels on his GC 640i used spacers on the front. Thanks guys
