12-01-2017, 03:57 PM | #1 |
Rep 631
drivers package
Can an M6 GC be upgraded or coded to raise the tope speed from 155 to the 189 MPH? What are the changes required?
Thanks
F06 M6 Grand Coupe CP
12-01-2017, 04:24 PM | #2 |
Rep 804
12-01-2017, 04:50 PM | #3 |
Rep 631
Thanks. Don't need it that bad. I just get to 150 at COTA back straight. The only other track might be Road America but I can live with that...
12-01-2017, 09:05 PM | #4 |
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
get it tuned, well worth the $$$. speed limiter removal, can run HFC's, no error code. And of course, 680BHP + from just a ecu tweak!
12-03-2017, 11:25 AM | #5 | |
Rep 443
How does one go about coding the vehicle to get 680HP!?!? The vehicle has to be a CP correct? Are there any other hardware items needed to get that HP (exhaust, headers, intakes etc.)? Thanks, H |
12-04-2017, 02:40 AM | #6 | ||
Rep 998
12-19-2017, 08:42 PM | #8 |
Rep 631
Is the Driver Package just a code change or is there hardware involved.
12-20-2017, 12:13 PM | #9 |
Rep 238
OBD Flash ECU is out. No need to drill to tune. Check the main new board for that.
Will it void warranty? Any medications you do can potentially void any warranty if the dealer thinks it was the cause of the error. Any changes you make you take a risk. |
12-20-2017, 01:30 PM | #10 |
Rep 804
Magic Motorsport is working on a solution for that warranty issue
12-20-2017, 03:43 PM | #11 |
Rep 238
http://esstuning.com/s63tu-stage-1-e...-ecu-software/
Just came across this. More companies are releasing their OBD option |
