      12-19-2023, 05:37 PM   #1
bahaa
Drives: Bmw F06 640i 2017
Crash bar, impact absorber and pedestrian sensor
Hello guys,
Sadly I had an accident in the front which caused damage to the car including the crash bar, I have ordered new parts but the crash bar that I got is a different one, looks like it’s an enforced one because it’s thicker and looks more stronger, now my problem is that on the old one behind the impact absorber sits the pedestrian sensor as you can see in the uploaded pictures, but I couldn’t find anywhere to place the sensor with the new crash bar and impact absorbers, any suggestions? Do I miss anything? Are they wrong parts?
Your help is very much needed
      12-19-2023, 06:22 PM   #2
Opie55
Drives: '15 650i Convertible
It's a bit unclear what you are saying the issue is. When you say the new one is thicker, are you referring to those thick aluminum "boxes" that are attached with rivets to the new bar? And your old bar did not have those? If you post what part number you ordered, and post the last 7 places of your VIN, I can look up the part number.
      12-20-2023, 02:35 AM   #3
bahaa
What I have ordered:
crash bar 51117385208
impact absorbers 51117370378
I think I needed:
crash bar 51117385207
impact absorber: 51118050349
Correct me if I'm wrong, my VIN is: GA00033
      12-20-2023, 09:03 AM   #4
Opie55
So if you go to RealOEM.com and plug in the VIN you gave me it does recognize your car as a European market 640 Gran Coupe made in August 2016. It only lists one crash bar for your car regardless of whether you have MSport bumpers, and the 207 number is correct, so you did order the wrong part. It's not entirely clear what the one you ordered fits. As for the impact absorber, the 349 number is correct IF you have MSport bumpers. If you don't have MSport bumpers, then the one you ordered is correct (although you transposed the last two numbers - it's 87 not 78). Finally, there is a third part you probably need called a front lower mount. That has 2 different numbers depending on whether you have MSport.
      12-20-2023, 09:40 AM   #5
bahaa
I don't have M sport bumpers no, I think I've ordered the US-spec parts instead of the European ones, looking at ReamOEM.com looks like the US-spec cars doesn't have the Pedestrian Protection System as you can see, it's grayed out, so it doesn't have the sensor that I have, I think I need to disable it somehow.
Name:  Screenshot 2023-12-20 at 17.37.43.png
      12-20-2023, 09:57 AM   #6
Opie55
In the US, pedestrian detection, if the car is speced with it, is controlled by a camera at the top of the windshield.
      12-20-2023, 10:06 AM   #7
bahaa
it's a sensor to help when hitting someone not for detection, do you know if it's possible to disable it by programming?
      12-20-2023, 04:49 PM   #8
Opie55
I don't know.
      12-29-2023, 10:59 AM   #9
SAUTAH
Drives: BMW F13 2012
It is possible to disable. You have to disconnect the pyro devices on the rear of the hood and on th hood latches. 4 in total. You also need to disconnect all of the pedestrain sensor plugs behoind the bumper. 3 from memory
And then code it out with E SYS.
https://www.google.com/search?sca_es...9yTIcIAww,st:0
      12-31-2023, 11:13 PM   #10
Cincinnatus
Drives: 2013 M6
Wait. What??? Are you saying that the system alerts you when you've hit someone? Like that big dent in the hood and grease spot under the wheels isn't a clue? I must be missing something.
