      05-15-2015, 04:17 PM   #1
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Coming Soon - Modified/Upgraded Turbos, Methanol, & Custom EuroCharged Tune
I contacted EuroCharged in Houston, TX and spoke with Jerry Thornton who owns the company. We will be installing modified/upgraded turbos (similar to what AMS and Vargas offers). The new turbos should have a flow rate good for up to 800whp.
After swapping out the new turbos Eurocharged will be custom tuning the car to the upgraded turbos and methanol injection. Eurocharged has the best dyno machine that DynoJet offers (model: 424xLC2) which includes the Eddy Current Load Control option and the 424 Linx System option. This means the front wheels of the m6 will be spinning at the same speed as the rear wheels giving it a true rolling experience (the m6 won't throw reduced power warnings).
I am hoping to achieve 750-775whp and I think it's absolutely possible given that I have seen an m6 without upgraded turbos and methanol pushing 724whp on a custom tune using the DynoJet.
I will post follow up posts as the project progresses. This is really exciting as long as I don't break the drivetrain in the process... lol!
Brian
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast
      05-15-2015, 05:10 PM   #2
m6beast
m6beast's Avatar
185
Drives: stock m6
Brian
Awesome bro! Can't wait and good luck!
      05-15-2015, 05:42 PM   #3
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
Awesome! You are inspiring envy and some bad ideas over here...
      05-15-2015, 05:47 PM   #4
Roadrage
Drives: M6 GC
Great news can't wait to see the results and the best of luck with project.
2014 M6 Gran Coupe, Strasse Forged 22", AMS DP, H&R Springs, Vorsteiner Carbon Aero Lip, IND body parts, side markers, carbon mirrors and spoiler, carbon diffuser.
      05-15-2015, 06:28 PM   #5
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
It should be a wild ride once all said and done. We will baseline the car with the current setup and then get a final number from the DynoJet.
Jerry did call me earlier and said their DynoJet machine doesn't provide a "wildly high" number like other DynoJet machines. Jerry said their machine provides a more true/accurate number due to their machine having the Eddy Current Load Control module. Jerry said this provides what they have tested/validated to be a more accurate number given various C63 Mercedes they have tested. So the number won't be wildly high like some DynoJet machines but the baseline will show the increase from my current setup.
He also said (which is refreshing) they know the breaking point of the DCT (or have a good idea) and can limit the boost pressure in the given RPM range so we don't grenade the transmission. He also said from what he has heard the axles and half-shafts will break before the transmission -- which is a good thing.
We are going to tune for maximum power on methanol. We are either going to wire in a relay to the fuel pump for the fuel to shut off in the event the meth pump fails or wire in a buzzer inside the car if the meth pump fails/stops flowing.
Brian
      05-16-2015, 10:09 PM   #6
HoustonRider
big pimpin
Drives: 2014 M6 GC and 2015 4 GC
I think the axles and shafts are the weak link, that's usually the case.
      05-17-2015, 09:36 AM   #7
BTF13M6
BTF13M6's Avatar
Drives: 2013 BMW M6 Coupe
👊👌looking forward to it!
2013 F13 ///M6 Coupe - Singapore Grey
20" ADV.1 5.0 MV1SL with Pirelli Pzero's
Custom Painted Grill, side markers and tinted front reflectors, Dinan Stage 1.
      05-19-2015, 07:36 PM   #8
A Frankfurt
Drives: German
Cant wait Brian !!!
Excited to see your build. Please upload pictures during the process if you can.
Have you thought of upgrading your clutch while your doing all of this ?
      05-19-2015, 11:18 PM   #9
Msizzle
Drives: 2013 M6 Coupe
in for results, good luck!!
      05-20-2015, 09:58 AM   #10
AstonMartian777
Drives: 2014 M6 F06
I want upgraded turbos as well
      05-20-2015, 10:04 AM   #11
AstonMartian777
Drives: 2014 M6 F06
If I were you I wouldn't tune it to meth, because then you would have to depend on meth, in your case I would allow jb4 to control meth, that way you can always go to stock boost, and btw get ready to get a clutch as well
      05-20-2015, 04:12 PM   #12
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Originally Posted by Autohaus Frankfurt View Post
Cant wait Brian !!!
I've talked a Jack at Jacks Transmissions who does a lot of trannys for the GTR guys. He can upgrade the clutches so it's an option if I want to move forward with it. I didn't get pricing from Jack yet but word is once all said and done (labor, upgrade, shipping) I will be in it for $5-6k.
I think for right now I am going to take it one step at a time. I am going to see what the tune actually puts down because at this point it's unknown. If I at that point I feel I might need to upgrade the clutches I will definitely dive into it more with Jack.
I have went back and forth on whether to tune it for meth or not tune it for meth and it's for the exact reason you stated (I will always have to depend on it). From a safeguard standpoint I have a 6.6 gal tank, I have an LED indicating "low tank" located on the rear view mirror assembly, and I have another LED mounted in same location indicating if the pump has built pressure (squirting liquid). I also have a wideband gauge mounted next to the Alky control box so I can "test" the system (with the test button) and watch the air/fuel change indicating the system is working/squirting.
As for the JB4... I would like to avoid simply "upping the boost" with the JB4 box as a "tune for meth" because although this is working for people I personally think there are other variables you have access to in the ECU that would result in a safer more efficient way to tune for meth. I say "personally" because nobody really knows what the car "adapts" to pertaining to timing and fuel when you up the number on the JB4 box. At least with the ECU tune you absolutely know what those numbers are set at and can control them.
I do understand your point in that I might not always want to run meth which is something I have taken into consideration. I am hoping sooner or later we will have ODB2 access which will then allow us to easily change maps (pump gase, race fuel, meth, etc, etc). That would eliminate that concern for sure.
Brian
      05-23-2015, 03:19 AM   #13
Majestic
Drives: 2014 Bmw M6
Damn BigBrian - it's getting even more serious! Looking forward to seeing the progress and results!
2014 BMW M6: Competition/Executive/Drivers assist+/Carbon Ceramic brakes, B&O Sound, Nightvision, Escort 9500Ci w/ laser shifters, AMS Catless DP's, Akrapovic Evolution exhaust, Dinan Stage 2 ECU Piggyback, Dinan Intakes, Full Vorsteiner accents, M Performance steering wheel, carbon fiber shifter, Awron vent gauge.
2017 BMW X6M: In the process of modding
      05-23-2015, 10:35 AM   #14
M6J
M6J's Avatar
35
Drives: F13 M6
Your insane in the best possible way Brian
      06-15-2015, 07:56 PM   #15
A Frankfurt
Drives: German
How is this coming along ?
Very excited to see the results
      06-15-2015, 08:35 PM   #16
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Still waiting on the turbos to be built. Last I heard they were at the machine shop last weekend. Sure is taking a long time if you ask me but then again I have no experience with how long this type of stuff takes so maybe I am just being impatient.
I am having the clutches upgraded as well to a clutch pack that supports 900ft pd of torque. Along with the clutches I am going to use a billet clutch basket and install a new pump w/ bronze bearing.
Brian
      06-16-2015, 12:51 AM   #17
BimmerGuy25
Drives: '14 X6M '14 M6 '15 C300
Sounds great Brian, in for results!
      06-16-2015, 03:13 AM   #18
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Brian
Just thinking that, now sure how long the drive train will last, good luck with it anyway.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      06-16-2015, 08:31 AM   #19
HoustonRider
big pimpin
Yeah I thought you were gonna be here this week.
      06-16-2015, 10:53 AM   #20
A Frankfurt
Drives: German
I agree with upgrading the clutch. Deff a necessity with that your planning on doing
Cant wait to see the progress
      06-16-2015, 01:50 PM   #21
AstonMartian777
Drives: 2014 M6 F06
BTW pure is coming out with turbos as well, Thanks !
      06-16-2015, 08:18 PM   #22
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Word is there are only a handful (if that) turbo manufactures that upgrade the turbos (here in the US). So when you have places like AMS and others selling them they are not building them in house -- they are having someone else build them and then they brand them.
Brian
