05-31-2016, 01:23 AM | #1 |
Rep 407
KW H.A.S. on M6GC comp?
Should I or should I not? Any gains? I assume I would gain approx .5" lower???
TIA for any comments/advice Btw, did a search on here and didn't find much about this combination
Past Vehicles "02" M3 (sold), "10" M3 (traded in), "11" M3, (sold ) "12" X5M (sold) and "16" M6GC (sold )
05-31-2016, 12:42 PM | #2 |
Rep 1,804
Gains from a suspension?
The HAS is a great suspension for these cars. I would definitely recommend it to anyone. I can refer you to a dealer that has a great price on these if you haven't purchased already.
05-31-2016, 07:01 PM | #3 |
Rep 676
Drives: 2015 M6 Gran Coupe
I have the KW HAS on my GC. Lowered a little over an inch. Rides perfect.
06-01-2016, 01:11 AM | #4 |
Rep 407
06-01-2016, 01:13 AM | #5 |
Rep 407
I have one quote, just started shopping. Feel free to PM me the referal. Thanks
06-01-2016, 06:24 AM | #6 |
Route Runner
137
Rep 661
Was wondering the same. I currently have Eibachs on my M5 and they ride great. Im thinking if i should just stick to Eibachs when my GC arrives or try the HAS. Anyone with the KW setup in the Northeast with these terrible roads?!?
16 SMB M6 Gran Coupe
16 BS X6 X-line (wife's truck) 13 AW M5 (sold) 04 Honda Pilot (everyday car) |
06-01-2016, 10:55 AM | #7 |
Rep 676
I don't know the exact settings, but I did add spacers 10mm all around
There are no Eibachs available for the M6 |
06-01-2016, 12:25 PM | #8 |
Rep 739
Im going with the HAS kit for my F12... have heard nothing but great things and its a huge plus having the option to adjust the height.
IG Page: @bo_buttaa
06-07-2016, 08:14 PM | #9 | |
Rep 616
Have installed HAS on the coupe, convertible and gran coupes now. All positive feedback. Both the KW HAS and Dinan Sleeve kit work the same. KW offers a lower stance over the Dinan but both function just as we would expect it. After the pictures below we actually adjusted the suspension lower. But the client wanted to get used to the lowered stance first since we also installed Vorsteiner front splitter and rear diffuser. |
06-07-2016, 11:15 PM | #10 | |
Route Runner
137
Rep 661
06-08-2016, 07:52 AM | #11 | |
Rep 739
If i lived out west of down south, I would opt for 21" wheels in a heartbeat. But not in the concrete jungle. |
06-08-2016, 07:53 AM | #12 | |
Rep 739
06-08-2016, 10:39 AM | #13 |
Rep 616
06-08-2016, 10:44 AM | #14 | |
Rep 616
You are not replacing the shock You are transforming your stock shock to a coil over If you keep the adjustment within range that the parts come with. You will enjoy the ride quality. If you adjust the KW kit past what is recommended, then you loose that. |
06-08-2016, 12:13 PM | #15 | |
Route Runner
137
Rep 661
06-08-2016, 12:20 PM | #16 | |
Rep 616
The drop is pretty aggressive. No complaints either other then it is nice to have the ability to adjust a preferred height if you needed it This is our shops F06 M6 on 21's White we had H&R springs. After getting it wrapped I installed the HAS kit. |
06-09-2016, 06:51 AM | #17 | |
Rep 48
Your car is awesome ! |
06-28-2016, 07:53 AM | #19 |
Rep 739
Car sits perfectly.
My local shop advised me against the H&R spring drop... stating the ride will be very "bouncy" for NYC roads. They recommended the KW HAS kit. |
06-28-2016, 01:36 PM | #20 | |
Rep 616
It all depends on the height that they are setting the adjustment to. You have EDC shocks I assume. So really, there is no adjustment to the shock travel because it is electronic. You are just setting the height of the spring which you are going to lower then stock anyways. Just my input but I don't see how the 2 would make a difference unless you did not have EDC and you were actually adjusting the stiffness, etc like a tradition coil over suspension setup. |
06-28-2016, 01:50 PM | #21 |
Rep 12,654
The KW just rides / feels better. H&R on these cars are bouncy and not appealing at all. Same when I had my M4 and tried out the H&R. Took them off the next day they were so bad.
07-03-2016, 01:16 AM | #22 |
Rep 195
Drives: 2014 M6 GC
I am running the KW H.A.S. System & at it lowest setting and it rides awesome.
