      02-02-2016, 01:47 AM   #1
Royce Martin
Royce Martin
Royce Martin's Avatar
Drives: 2013 650i xdrive GC
F06 M6 Exhaust Vs F06 650i Exhaust
I've been searching the web and looking at youtube videos for the past 3months. I just can't seem to wrap my head around the difference between the exhaust in the 650i and the M6.
The engine in the 650i and the M6 is identical (correct me if I'm wrong). Both 4.4L V8 yet the exhaust notes differ, why is that?
      02-04-2016, 04:14 PM   #2
S800vxr
Drives: F13 M6 Coupe
Engines are far from identical apart from capacity really. No throttle butterfly on the M6, totally different manifold and turbo setup, twin water Cooled ecu's vs 1 on 650, totally different inlet and intercooler setup etc etc.
      02-04-2016, 10:33 PM   #3
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Cross Bank Exhaust Manifold on S63. Creates equal pulses side to side to counteract the firing order on each bank.
      02-05-2016, 12:23 AM   #4
AstonMartian777
Drives: 2014 M6 F06
I had 650 before my m6 and stock for stock 650 m sport sounds better
      02-05-2016, 07:19 AM   #5
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Yeap! The stock M6 exhaust is totally emasculating
I think this is why BMW FINALLY went to Akra and cut a deal for an akra sourced BMW M Perf bin exhaust option to fix their oversight or short sightedness
This was one of the reasons I kept my 2007 M6 for so long as the new M6 sound sucked ... My two S63 Amg's has batter sound, which says a lot for the AMG teams focus ... And a let down for the M division
It should be noted I did add the Eisenmann sport cat back to my 2007 in about 2010 just for the look as the sound was already amazing and only a little better with the eisenmann
The X5M exhaust they got right ... Same engine
Here is hoping the next gen M6 has the proper exhaust note ... Or else my dealer will be storing yet another stock exhaust!!! Or I may not be back to buy a next Gen M6 for a while or jump ship to 911 or Benz for a rag top option. (after 170k canadian for a full load car without comp package or carbon ceramic breaks ... another 10k for a proper exhaust set up to help with the car's attitude and presence ?)
Love the player ... just not sure about what the team is playing
      02-05-2016, 12:39 PM   #6
S800vxr
X5M is slightly different as the tu engine variant in the M6/5 used inlet valve lift control for throttling rather than a traditional butterfly arrangement which the X5M uses... Might have changed for 2016 though as emissions are better on the tu variant.
      02-05-2016, 01:19 PM   #7
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
F85/86 use a new variant with Valvetronic as on the M5/M6. Few additional changes as well.
G11/12 750i with the latest N63 uses twin-scroll turbos as well so it too has the cross bank manifold.
One common thing between them is the electric exhaust flaps. Just my opinion but I think they probably programmed a little offset pulsing back in for acoustic masculinity
      02-05-2016, 09:39 PM   #8
2007 to 2016 M6 Cab
Thanks!!
Many good points!
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      02-06-2016, 01:06 PM   #9
speedracerlo
Drives: 2015 M6 Gran Coupe
just delete the damn mufflers and make it sound like it was supposed to
      02-16-2016, 12:08 AM   #10
2007 to 2016 M6 Cab
YEAP +1
Current Garage:
Past Cars:
      02-16-2016, 12:35 AM   #11
Royce Martin
Royce Martin
I wouldn't change the exhaust if that was the case. I want something better looking and better sounding. That's what I thought prior to knowing that the M6 exhaust is weak. I'm interested in aftermarket now.
      02-16-2016, 12:39 AM   #12
2007 to 2016 M6 Cab
Turner muffler delete and new tips may just do the trick ... +/- resonators and down pipes ... See what is on line for options ... Looking at it now ... I love the Akra for sound and look but the turner muffler delete and new tips may have been a more cost effective approach for a similar sound ... I already had airs ordered by the time I discovered turner ... See what the web has to offer
      02-16-2016, 12:57 AM   #13
Royce Martin
Royce Martin
Can you send me url links to what you've found?
      02-16-2016, 01:27 AM   #14
2007 to 2016 M6 Cab
There is a thread in the M6 post with this info for the M6
      02-16-2016, 01:30 AM   #15
Royce Martin
Royce Martin
I have an F06 650i Xdrive.
      02-16-2016, 01:31 AM   #16
2007 to 2016 M6 Cab
I'd Google turner muffler delete
      02-16-2016, 01:35 AM   #17
2007 to 2016 M6 Cab
f10.5post.com
      02-16-2016, 01:39 AM   #18
2007 to 2016 M6 Cab
Google: 2014 650i muffler delete
      02-16-2016, 01:49 AM   #19
Royce Martin
Royce Martin
I apreciate it, I'll check out that 5post forum.
      03-30-2023, 03:11 PM   #20
jonasyeo
Drives: BMW f06 650i
Inside of 2013 650i F06 exhaust
Inside of 2013 650i F06 exhaust.
This mod makes them looks completely stock, but sounds great now.
      03-30-2023, 08:47 PM   #21
LA640WS
Drives: Vert 640, Merc SL63 R232
Thanks for the visuals!
Fire! Thanks for posting the pics, running to the shop!! But why does it look like they shoved a dead dog in that belly?
