      08-06-2017, 02:41 PM   #1
Evil Derboy
Evil Derboy's Avatar
Drives: E92 M3
Upgrading stock exhaust tips
Hi everyone,
I just picked my San Marino coupe up yesterday. I really like the look of the akrapovic style exhaust tips with the carbon sleeve but don't want to change the stock exhaust system.
See a lot of tips on ebay but confused about sizes etc. Has anyone swapped out the tips only?
Thanks.
      08-06-2017, 11:16 PM   #2
hjs1971
Drives: 2017 x5m, 2012 m6 convertible
Cyba cf tips look/fit great
2013 Alpine White X5 3.5xdrive Daily driver.
2012 San Marino Blue Metallic M6 convertible with silver stone interior. No mods. Weekend cruiser.
      08-08-2017, 06:58 AM   #3
Evil Derboy
Drives: E92 M3
Cant seem to find anywhere to buy them. Any tips?
      08-08-2017, 07:19 AM   #4
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
http://www.ebay.com/itm/M-Sport-Real...pYmr~G&vxp=mtr
JayM632.50
      08-08-2017, 04:18 PM   #5
Evil Derboy
Drives: E92 M3
Originally Posted by mjposner View Post
I've seen these all over eBay but I'm confused about sizes. Do the stock exhaust tips slip on like on the M3/M4 and if so those ones in the link look as if you'd need to cut down the existing pipe rather than slip these over.
      08-08-2017, 04:24 PM   #6
BMWDriverX
Drives: G12 750i X-Drive
They slip over and bolt. Or you can go with Burger Tuning tips which also slip over and use set screws. A quick search on google for BMW slip on tips and you will find everything you need.
      08-08-2017, 05:22 PM   #7
Evil Derboy
Drives: E92 M3
Sorry. Not sure where the Off-Topic emoji came from was typing on my phone.
I've been Googling slip-on tips for M5/M6 for the last few days but cant seem to find a definitive answer in terms of fitment. That link you sent me says that the inner is 63mm but I've read that the stock pipe is bigger.
Also the Burger Tuning tips make no mention of M5/M6 or 5/6 series. Is the exhaust the same size?
      08-08-2017, 05:57 PM   #8
BMWDriverX
I would think they are different because if you look at this link it asks you to specify M3/M4 or M5/M6 for ordering.
http://www.burgertuning.com/billet_e...M4_M5_BMW.html
      08-30-2017, 11:41 PM   #9
chador
Drives: BMW M8 GC Competition 2020
I ordered about 16 of these from the manufacturer in China. Was going to buy the eBay ones, but figured I could find the Chinese source and I was indeed able to. For the same price, I got 16! When I get them I will do a full pictorial so we can see once and for all what size these things are and how to install them.
      08-31-2017, 12:04 PM   #10
Evil Derboy
Drives: E92 M3
I went with the chinese ones as well. The main problem is that the M6 tail pipe is wider at the end but that wider section is only about 2 inches long and then the pipe narrows. The chinese tips have a hoseclamp at the end that will grip the wider section but not the narrower part.
Which basically means to use as intended the tips will stick far too much out behind the rear bumper. In the end I removed the hose clamps, drilled a hole through and bolted them on. Allows for the correct length and is pretty solid.
      08-31-2017, 03:07 PM   #11
BMWRog
Drives: 2014 M6 Convertible
Sounds a good solution. Pics would be good, if you have time...
      08-31-2017, 03:48 PM   #12
Evil Derboy
Drives: E92 M3
No problem. Here you go:
      09-01-2017, 07:12 AM   #13
Moozi20
10
Drives: BMW M6, Alfa Romeo Giulia
2013 BMW M6  [10.00]
They look great! are you willing you share where you got them from? I have been on the lookout for some that would fit the stock exhaust. Like you i would like to keep my stock exhaust (for now...)
      09-01-2017, 11:39 AM   #14
BMWRog
Looks awesome! Thanks Derboy. Very
      09-01-2017, 01:51 PM   #15
Evil Derboy
Drives: E92 M3
Sorry I forgot to post the link earlier. Here you go:
https://www.aliexpress.com/item/Carb...311.0.0.2AQVpH
If you scroll down you'll see a pic withj the hose clamp. Remove this, drill a hole in the metal underneath and then slide the whole exhaust tip onto your exhaust pipe and line it up. Mark a dot through your newly created hole with a sharpy. Remove, drill the corresponding hole in your exhaust pipe and then you can secure it with a nut and bolt. I used stainless steel M6 philips head bolts with nylon locking nuts and a spring washer in each. Cost me around a tenner from B&Q
      09-05-2017, 03:28 AM   #16
garethm
Drives: bmw
Nice. Though I'm curious if CF exhaust tips will turn yellowish over time.
      09-05-2017, 04:21 AM   #17
Evil Derboy
Drives: E92 M3
Why would they?
      09-05-2017, 12:27 PM   #18
BMWDriverX
Why would they?
Cheap resin used to make the CF. All CF parts that come from China turn yellow/green over time as the resin absorbs UV. When auto manufacturers like BMW make something out of CF they use a very expensive resin and clear coat so the parts do not fade.
Flying Ace4984.50
      09-05-2017, 04:53 PM   #19
Evil Derboy
Drives: E92 M3
That's a sweeping generalisation. I have a carbon spoiler, door mirrors and b pillar trims on my Maserati Ghibli. All bought from Ali Express and now three years old with none of the issues you mention.
Not saying it won't happen but I wouldn't logically assume that every CF part made in the Far East will discolour unless it's sold by a branded manufacturer.
      09-05-2017, 04:57 PM   #20
BMWDriverX
Not saying it on't happen but I wouldn't logically assume that every CF part made in the Far East will discolour unless it's sold by a branded manufacturer.
Bring those parts out to the California sun on 115 degree days and you will see how long they do not last.
Over here if we tint our taillights, they warp and melt. I don't think you have those issues out there in Scotland?
      09-05-2017, 05:14 PM   #21
Evil Derboy
Drives: E92 M3
Fair point! You've got me there
      04-15-2018, 01:21 PM   #22
Madvillain
Drives: lada
What size did you order for these tips? I noticed on aliexpress the sellers for these tips have for example 67mm in and 92mm out. I assume the 67 is the bit that attaches to the muffler and the 92 is the bit we see.
