E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > 325i to 330i conversion successful! Dyno charts included!
Reply
      07-23-2013, 04:15 PM   #375
devilpit
Drives: bmw 325i
Originally Posted by e90pilot View Post
Spacemonkey, Your car will drive fine with only the manifold. I'm not sure who told you you can get more than a stock 330 but there is definitely no proof. Everyone's about 5 to 10 whp short of a stock 330. There's still something missing in the tune that BMW has hidden away. Also, I'd lose the AFE intake. It has been shown to lose power due to it's open airbox design. It heatsoaks easily. The stock design is pretty good, but it's quiet.
Francis, remember that not all dyno's are alike. Some measure estimated crank HP, some give more generous numbers, some are conservative. It's really hard to reproduce what actually happens on the road on a dyno. They're notoriously inaccurate because of the associated conditions of a run. My car has shown 218 on one dyno and 209 on another dyno of the same brand and type! Same tune as well. Even the pressure temperature, and humidity were close. The ecu is pretty sensitive to even the smallest change in conditions. But taking all of this into account, there is a gain in power and torque, but it's really hard to know exactly how much.
turner motor sport will do this manifold swap for 2300.00 complete...ecu, new 330i manifold, DISA, labor...260 flywheel horse power.
      07-26-2013, 12:02 AM   #376
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Really? So tuner is doing a real conversion
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-28-2013, 05:06 PM   #377
smellthebeans
smellthebeans's Avatar
Drives: LPCs
1990 325i  [0.00]
Originally Posted by optimaxedm3 View Post
I installed these in the following order:
PE, 3 stage IM, Performance Intake and then did AA tune (via Simon Tool).
There is a large difference between a stock car, and the final product.
There are still "flat" spots as I would call them throughout the rev band, but significantly better than without the tune.
If you have the N52 get a 3 stage intake, performance exhaust, and AA tune. I don't need a dyno prove there is more power. Car now easily steers with throttle modulation in 2nd gear, 3rd gear pulls much harder all the way up. Wonderful be back in my330i again, sans the larger brakes.
      09-23-2013, 12:19 PM   #378
Pierre1014
Drives: 2006 325i
Could I swap the intake manifold without the software? Would that affect anything?
      09-23-2013, 12:26 PM   #379
Delta0311
Drives: 2011 BMW 335xi E92 2016 228xi
No you need the software you won't see any gains without it.
      09-23-2013, 01:31 PM   #380
Pierre1014
Drives: 2006 325i
Any idea where I could get the software?
      09-23-2013, 01:39 PM   #381
Delta0311
PM any of the guys from ActiveAutowerke
      09-23-2013, 03:18 PM   #382
mike-y
just another bmw douche bag
Drives: 1.9L of fury
Not correct, you'll see gains, but not nearly as much as with the software. on a 325i, the biggest gains are down low below 2800rpm (+15 to +20 ft/lbs), and more moderate (~10whp) gains up top.
But there will be a hole in the powerband around 4000-4500, until you get the tune.
      09-23-2013, 03:28 PM   #383
Pierre1014
Drives: 2006 325i
But there will be a hole in the powerband around 4000-5500, until you get the tune.
I checked the website the other guy gave me but they only have the
Active Autowerke E9X 325 & E9X 330 (2006-2007) Performance Software is this the software I need? Bc there's nothing else for the n52 engine .. If not is not it any idea where I could get it ?
      09-23-2013, 04:02 PM   #384
Delta0311
Yes that's it.
      09-25-2013, 08:59 PM   #385
Pierre1014
Drives: 2006 325i
Yes that's it.
Does it have to be that specific software or just the 330i software in general ??
      09-25-2013, 11:50 PM   #386
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Tell them you did the conversion. They'll tune your ECU file to the proper spec.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      09-26-2013, 06:53 AM   #387
Pierre1014
Drives: 2006 325i
Down here in NY no one seems to now anything about this
Conversion that's why I'm asking so I could just tell them what
I want you know what I'm saying.. Bc if the software I need is the Active Autowerke E9X 325 & E9X 330 (2006-2007) Performance Software I could just buy it and have it put on but if it's the 330is software I could just reflash my ecu with the 330i's software.. Was the Active Autowerke E9X 325 & E9X 330 (2006-2007) Performance Software the one you used?
      09-26-2013, 07:03 AM   #388
Delta0311
Get this
http://store.activeautowerke.com/act...ware-p124.aspx
and GET THIS!!
http://store.activeautowerke.com/act...px?Thread=True
Reason you want the tool is so that you can do the flash yourself. If shops in your area are clueless than this is the way to go. If you need a reflash you can do it within minutes and not have to worry about finding a shop and having to pay everytime something has to get fine tuned.
      09-26-2013, 07:41 AM   #389
Pierre1014
Drives: 2006 325i
Alright.. The first link you gave me is for the 328i and 128i but it says it works for n52 engine as well any differentces between the two? (Active Autowerke E9X 325 & E9X 330 (2006-2007) Performance Software and the Active Autowerke BMW 328i BMW 128i Performance Tune Software) hahha so many questions man lol sorry
      09-26-2013, 07:55 AM   #390
Pierre1014
Drives: 2006 325i
Get this
and GET THIS!!
      09-26-2013, 08:09 AM   #391
Delta0311
It is for your car... Email them before purchasing and they will make sure you get everything you need.
      09-26-2013, 08:33 AM   #392
Pierre1014
Drives: 2006 325i
I did email them but I never got am answer from them that's why
I'm trying to figure this out lol
      09-27-2013, 10:46 AM   #393
mike-y
when you order the tune from AA, they ask you your mods. you say "325i with the 3stage manifold (or 330i manifold)" and they'll modify the correct files for the tune. You can't just flash 330i software - unfortunately, it's not that simple on these cars as each car's software is bound to it's VIN, and individual files are sometimes located in different areas of the software.
your local shop will need to download your car's DME files, then email that to AA, then re-flash the file after AA modifies it and returns it to them.
you can also use the simon to flash the tune if you have extra money to burn, but the 325i/330i use a different computer than the 328i, so you have to make sure you get the right software for your specific model.
      09-27-2013, 10:51 AM   #394
Delta0311
Exactly, which is why I recommended he gets the tool. Since he will first have to backup the DME file for AA to make adjustments and then flash the new file. So that is at least 2 trips to the shop and that is if everything works 100%, otherwise you will have to reflash.
      09-27-2013, 01:03 PM   #395
mike-y
my shop didn't charge me anything extra for the two trips.. but if your shop isn't competent, the extra money for the simon tool may be justified.
but honestly, all they are going to do, is plug your car in, and download the software from the OBD2 port, then send it to AA. then plug your car in again the next day (or later the same day) and re-flash the software with a laptop. If they've ever flashed software before, this should be a no-brainer for them.
      10-23-2013, 08:11 PM   #396
Pierre1014
Drives: 2006 325i
So I ordered the AA tune but I never mentioned on having the 3 stage intake manifold swapt I hope that doesn't make a difference
Reply
Tags
330i coversion, active autowerke, manifold swap, n52, tune
e90post
