      12-27-2013, 11:45 PM   #1
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
M6 charcoal filter removal
Anyone have a step by step process? I did a search and naturally got 100's of posts unrelated to this lol
2024 Porsche 911 GTS Cabriolet
      12-28-2013, 11:21 AM   #2
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Try this Luigi.
http://f10.m5post.com/forums/showthread.php?t=797677
      12-28-2013, 11:40 AM   #3
LSM
LSM's Avatar
Originally Posted by Tuned1M View Post
Perfect! Thanks Mike, now come help...
      04-05-2016, 02:25 PM   #4
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Resurrecting an old thread. Has anyone done this to their M6? Please chime in. Any adverse effects? From the M5 thread, looks like a lot of them are happy with the results.
      04-05-2016, 03:14 PM   #5
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
I did it first thing. No complaints.
      04-06-2016, 12:27 AM   #6
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Wow ... What did you butt dyno tell you??? Is it worth it?
      04-06-2016, 08:33 AM   #7
devondragon
Lol! My butt dyno said it made a small improvement, but butt dynos can't really be trusted I feel like I can hear more whoosh noise, which I like, and generally anything you can to free up airflow in a turbo engine is good. It didn't take long to do, although getting that first airbox open was a trick So in general I think it's worth it. Quick easy mod, can't hurt, might help.
      04-06-2016, 10:52 PM   #8
2007 to 2016 M6 Cab
Thanks!!
I'll have to do it as well!!!
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      04-06-2016, 11:13 PM   #9
Bobby_Drake
390
Drives: '16 X5M
Thanks. I'll have to give it a try.
      05-04-2016, 01:54 PM   #10
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
There's a MUCH easier way to do it: loosen and remove 1 bolt attached to the body (holding the air box in place), loosen clamp by MAF, remove MAF CAREFULLY, and pop out the airbox. Much easier than reaching the hidden bolt under the intake pipe.
Charcoal filter is for emissions only, in EUR they don't even use them. You'll notice a slight change in sound and performance. Very little, don't expect to spin the tires in 7th gear.
      05-23-2016, 05:22 PM   #11
Bobby_Drake
390
Drives: '16 X5M
In the M6, there is a black rubber piece that seems to hold the airbox in place in addition to the 1 torx bolt. How did you remove this?
      05-23-2016, 05:49 PM   #12
TheHouseWon
644
Drives: 2013 M5
With a little force. It pops on and off similar to the engine cover. They are grommet-like couplers. Just pull straight up...it's the same as M5
      05-25-2016, 12:46 PM   #13
Bobby_Drake
390
Drives: '16 X5M
Worked like a charm. I ended up removing the while filter box and cleaned them. Much much easier to do than try to access screw#7. It does feel more responsive - better throttle response. I replaced the filters with KNN.
      05-25-2016, 01:09 PM   #14
TheHouseWon
644
Drives: 2013 M5
That's great. I went with Knn as well.
Are you going to bimmerfest in Fontana this wkd? There are two caravans starting in UTC and Vista.
      05-25-2016, 02:42 PM   #15
Bobby_Drake
390
Drives: '16 X5M
Yea I'll be there. Are you guys leaving Friday or Sat? Wifey wants to hang out around OC friday so we'll be staying around the area Friday night.
