      09-14-2014, 12:12 AM   #1
L2Fly
Drives: F13
Side Fender
Guys, I've tried searching the forums, but the search feature is nowhere near helpful. I've been looking for a solid 40 minutes now for glossy black side fender pieces (where the side blinkers are) for my F13. Could someone send a link my way? Thanks, y'all.
      09-14-2014, 02:52 AM   #2
L2Fly
Drives: F13
http://ind-distribution.com/ind/bran...ed-side-marker
Found some, but they're pretty darn pricey. Anyone know where to get em a bit cheaper?
      09-14-2014, 09:22 AM   #3
vaio23
Drives: 650I
Is there a DIY for removing them? Wrapping them in gloss black vinyl should be simple and you will get the same look for under 10 dollars.
      09-14-2014, 01:13 PM   #4
L2Fly
Drives: F13
I saw in a thread somewhere that they clip in, but I could be wrong. If it's that easy, then you're dang right I'm doing that.
      09-14-2014, 05:12 PM   #5
ShakeDaddy
ShakeDaddy's Avatar
10
Drives: 2013 650i Coupe
Do the wrap, only way 2fly !!
      09-16-2014, 09:59 PM   #6
L2Fly
Drives: F13
Ha, I'll get on it this weekend, hopefully with the Eibach springs already installed too.
      09-16-2014, 10:55 PM   #7
m34SPD
Picture me rollin'
m34SPD's Avatar
Drives: e36 m3, e39 m5, f80 m3 CS
Can you post how to unclip them if you do it this weekend?
      09-16-2014, 11:54 PM   #8
L2Fly
Drives: F13
Will do, brother. College football and cars... Fewer things could add up to a better weekend.
      09-17-2014, 10:21 AM   #9
m34SPD
Picture me rollin'
m34SPD's Avatar
      09-17-2014, 12:00 PM   #10
Jamescc75
Drives: 2014 640i Xdrive Gran Coupe
Couldn't agree more! Also, let us know how you did the vinyl wrap
      09-17-2014, 02:09 PM   #11
Downfourit
Drives: M6 Gran Coupe`
I had them wrapped, they are on spring clips. You push one side towards fender or the door and then pop them out, use a plastic card to help get underneath and they will come out and then the chrome separates from the blinker assembly and I just took that to my tint shop and had them wrap it, they didn't even charge me but I have done a lot of work with them. It's been on there for a few months and looks great! I also did the chrome on the door handle at the same time.
      09-18-2014, 04:33 PM   #12
L2Fly
Drives: F13
Dayum, that's a good looking car. Thanks for the help!
      09-18-2014, 04:47 PM   #13
Downfourit
Thank you man, and you are most welcome!
      09-29-2014, 08:41 AM   #14
vaio23
Drives: 650I
I just wrapped my lights. As previously stated, to remove start with lifting the chrome end closest to the doors and continue lifting on the bottom. Once lifted move to the top (black trim) end of the trim closest to the door and put pressure until the spring clip releases. After that the middle clip comes out easily and slightly pull the trim piece back towards the door to unhook the far end from the fender, unclip the light and you are ready to go. You will then need to remove the chrome trim from the plastic light housing, using a small flat head screw driver press down all the clips to remove. Then you can wrap the chrome piece, here are a few pics.
      10-05-2014, 10:09 AM   #15
sk0525
Drives: '18 F85
Just did this last night. Looks so much better black than chrome!
If you're running to HD to buy some paint, go further down the aisle and pick up a bondo knife/spreader. Made the job so much easier and I put painters tape underneath just to be sure I didn't scratch the paint.
'18 X5M | '17 650i Gran Coupe | '07 Tundra CrewMax 4x4 | '06 Lancer Evolution IX MR
      10-10-2014, 08:03 PM   #16
L2Fly
Drives: F13
Do you still want me to put up pics on how to do this, man? It's really as easy as vaio said. I finally had the time to do it just now, and it took about 20 minutes to get the trim pieces out and a bit longer to separate the chrome from the black. Gonna take em to get wrapped tomorrow
      10-11-2014, 12:18 AM   #17
Krash7172
Drives: 2018 530e, 2020 X4
All depends on body color IMO. I'm not a fan of chrome myself. I blacked out my Space Gray 5 but left some chrome on my Moonstone 6. Definitely an easy and nice looking mod. Good job on the DYI.
      10-12-2014, 05:28 PM   #18
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Very easy to do. Followed instructions and popped right out. Pulled buttom first then top and just popped lose with some downward pressure. Thanks alot for the instructions.
Didn't even need a knife or tape for this on mine. Easiest set of side grilles I've removed. All I did need was a small screwdriver to slide in the light clip release point to get it lose from the light assembly. Took me 10 mins tops.
I went with custom painted ones to match my body color and light tint light markers from IND. Reasonable cost and much better than chrome I agree.
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      10-12-2014, 06:00 PM   #19
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Close up
      11-04-2014, 10:40 AM   #20
m34SPD
Picture me rollin'
m34SPD's Avatar
How do you remove the chrome piece? I got the part off the car, but I can't separate the chrome. I pushed down on the tabs, but I am not sure why they don't come off.
      11-04-2014, 01:52 PM   #21
m34SPD
Picture me rollin'
m34SPD's Avatar
So I didn't want to break the piece off, so I wrapped over. It looks really good. Up close you can still see some chrome on the very edge, but overall looks much better.
      11-04-2014, 01:56 PM   #22
m34SPD
Picture me rollin'
m34SPD's Avatar
