      02-15-2017, 09:38 PM   #1
thebmw
Post Advisor
thebmw's Avatar
1632
Exclamation Weird Noise Heard Inside F12/F13 BMW 650
I'm hearing a strange noise inside the car. It sounds like something is starting and stopping. It gets worse the longer the car has been on. Eventually, it sounds like someone is dropping rocks into a bucket of water. I can only hear the sound from the cabin. I can't hear it when I open the hood and the car is on...most likely because the engine is drowning out the sound.
Here is the link for the sound:
You can definitely hear the rhythmic sound every 1.8 seconds. Any ideas? The car barely has 20K miles!
      03-17-2017, 12:31 AM   #2
thebmw
Post Advisor
thebmw's Avatar
1632
I've updated the sound so you can hear it better. Please help!
      03-17-2017, 06:40 AM   #3
Walt White Coupe
Walt White Coupe's Avatar
221
Is that with the engine idling in neutral?
      03-17-2017, 08:08 AM   #4
thebmw
Post Advisor
thebmw's Avatar
1632
Yes, but the sound is always there I believe. The car is a rare 6 speed manual. The sound is there when it is in neutral, in gear with the clutch down, or driving. It is harder to hear when driving because of the engine and road noise but I can feel the cluncking slightly in the steering wheel so I know it's always there.
      03-18-2017, 03:23 AM   #5
650i2014
Drives: 650i
Do you hear the noise when the AC is off?
I experienced a similar noise for a few days (only when the AC was on), the day it was due to be inspected by the dealer it miraculously disappeared. The dealer was suspecting it could be the AC water drainage but they couldn't find anything wrong with it.
Give it a few days and it might disappear
      03-19-2017, 08:58 AM   #6
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
Heater core?
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      03-19-2017, 04:36 PM   #7
thebmw
Post Advisor
thebmw's Avatar
1632
Another poster on another forum seems to have hit it dead on. It is an air bubble in the heat exchanger. Probably would exist with the heat or A/C. I turned the fan off and the sound disappeared. That annoying noise has been going on for 4 months. Dealer said it was an intercooler...wrong.
Solution: drain/bleed the fan/heating/cooling circuit. Does anyone know how that is done?
      03-19-2017, 08:46 PM   #8
doug_999
doug_999's Avatar
2542
I believe that is called the heater core
