      10-04-2016, 09:14 AM   #1
darms
darms's Avatar
56
Hardwire Ctek Battery Conditioner
Hiya
I've done some searching online but can't find a definitive answer how to hardwire a ctek battery conditioner.
I don't really drive my car much and wanted to keep the battery at its optimum charge.
Option 1 - install a m8 connector directly to the battery
Option 2- install a m8 connector under the bonnet/hood
Connectorhttp://www.ctek.com/gb/en/chargers/C...%20Eyelet%20M8
Has anyone done this before? My car will be outside and therefore would prefer actual charger to be in the car (if possible) away from the elements
Thanks in advance
F30 LCI M Sport Shadow Edition Mineral Grey
      10-04-2016, 12:38 PM   #2
BDO
Drives: 2016 X6 40d M-sport
Under the bonnet using the jumpstart battery posts.
      10-10-2016, 04:00 PM   #3
drmlee
Drives: F06 650i
i wired mine straight to the battery in the trunk. takes like 2 min. i can close the trunk with the wire coming out of it, but i leave the charger outside. if you needed to put the charger inside, the cord/plug part of the wire is alot thicker than the other part. i dont know how you're going to have the charger inside in the hood or trunk and still be able to close everything.
      10-11-2016, 03:40 AM   #4
BDO
Putting the charger inside the trunk/hood and closing it would be dangerous and frankly quite stupid.
      10-11-2016, 08:27 AM   #5
E90Fleet
South Africa
1312
Also remember it is best with these cars not to wire the negative charger terminal to the negative battery post.
You should wire it to a negative post on the car body.
This prevents errors that can occur in electronic systems such as the electronic battery sensor (IBS)
Personally I dont hardwire my CTEK's.
I got their "crocodile" clamps and use the under hood terminals when charging.
Makes it easy to use one charger on multiple cars aswell.
BMW if you are reading, I need a job, Please.
      10-11-2016, 08:44 AM   #6
darms
darms's Avatar
56
Thx guys for your comments
I went and ordered one of these to hard wire and after speaking to a number of people looks like the bonnet option is the BMW approved route
[IMG]http://smartercharger.com/wp-content...tor_Eyelet.jpg[/IMG]
Gonna be wiring it up tomorrow. Got two cars so will be moving the charger from one to the other from time to time
      10-12-2016, 09:17 AM   #7
darms
darms's Avatar
56
Installed
[IMG]http://img.photobucket.com/albums/v6...774224457B.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v6...12B7DFA943.jpg[/IMG]
