      09-09-2016, 12:38 PM   #1
Dogmatic6
Drives: BMW X4M Competition
Does my 2013 640D have TPMS?
Hi all,
Did all 6 series cars come with TPMS with the sensors in each wheel? Or was it an extra? I think I have the basic system with no sensors as my tire valves are rubber and not metal?
Just wondering if it should have them or not.
Cheers
      09-09-2016, 03:02 PM   #2
chris.t
chris.t's Avatar
28
Drives: 2014 BMW 640d msport
i thought they all came with tpms, i have rubber valves caps on mine but i swapped them from the metal ones.
Present 2014 BMW 640d msport
Previous 2012 BMW X5 30d msport
      09-10-2016, 11:30 AM   #3
Dogmatic6
Thanks for the reply! I'm not so sure though
I tried to code the tire pressure to display on the screen but it didn't work.
      09-10-2016, 01:46 PM   #4
drmlee
Drives: F06 650i
the only cars ive seen that use rubber valve stems with a tmps on screwed on inner is chevy/gm cars. all bmws after around 2005-06 with TPMS should have an aluminum valve stem that can be seen on the wheel. if you have a F series 6, it should have tpms as standard. when you check in idrive, does it show you the car with the psi in every wheel?
      09-12-2016, 07:20 AM   #5
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
As per my 2011 640i, early 'F' model 6 Series did not have TPMS. I think it was introduced after 2012.
Externally it can be identified by an aluminium valve stem with a hex nut at the base and as a previous poster mentioned, you'll get an actual pressure figure for each wheel in bar or psi on the control display.
      09-13-2016, 11:16 AM   #6
bmwak
bmwak's Avatar
105
Drives: 440i M-Sport Gran Coupe
My late 2013 640d doesn't have TPMS either. I do not think all cars had them, it was a pre-2014 optional extra.
I am currently looking into retrofitting it - which involves changing the valves on all four wheels, but the difficult part is wiring the control unit (coding is easy).
      09-14-2016, 07:04 AM   #7
Dogmatic6
Thanks for the responses everyone!! I guess it looks like tpms didnt come as standard before 2014 then
Would be interested in hearing with how you get on with retrofitting bmwak
As you say, coding & wheel sensors will be easy but not sure how hard the control unit would be to fit or how expensive.
Cheers
Mark
      02-19-2017, 01:40 PM   #8
6coupe
Drives: M6 GC
Anyone have a picture for what the TMPS receiver looks like on a 6 series? I believe it's in the boot, but don't know if I have one or not. The wheels have normal valves, but I want to fit TPMS valves, so need to check if the other parts are already in place. (2011 640d)
I have the menu on the iDrive, but can't recall if I coded it to be there or not, I think I just coded the tyre temps to be shown with the pressure, but of course none of it 'works' as no sensors in the wheels.
Thanks
      02-19-2017, 11:26 PM   #9
upstate650
upstate650's Avatar
2020 BMW M340xi  [0.00]
I believe all modern cars come with TPMS sensors. Not sure what year it started but it's mandatory now.
      02-20-2017, 03:52 AM   #10
Scottiedog
Drives: 435d GC
Originally Posted by Dogmatic6 View Post
Hi all,
Cheers
Cars built April 14 have it as standard otherwise it was an option.
      02-20-2017, 04:09 AM   #11
6coupe
Drives: M6 GC
I suppose it could have had the option from factory, but when sensors needed replacing they cheaped out and put normal ones on?
The menu option is there, i would've guessed it wouldn't be there unless the option was there...? Wanting to confirm visually before ordering 4 new sensors.
Thanks
      02-21-2017, 06:28 AM   #12
elvisisdog
Drives: F06 MSport 2013/09
Just chipping in here - how often do the valves need to be replaced? I'm assuming they're not replaced every tyre change? Previous owner of mine must have like the hand car wash places in the UK as the valve stem rubber at the point it contacts the rim looks perished to me and the aluminium is corroded heavily.
Had a quick google as one of the wheels has rubber valve stem and was coming up around £50 a valve stem - does this sound about right?
