08-18-2015, 12:25 PM | #1 |
Rep 73
Drives: 2017 650i GC xDrive M Package
Oil Consumption
My car just hit 3500 miles. Barely broken in I got a message on my screen to add 2 quarts of oil. I stopped by the local dealer and they topped it off. What is your experience/ knowledge about oil consumption etc.,
Upon delivery back in April 2015 I noticed that I had a broken lock in the center console. As I brought back for the repair to my dealer and they also did an oil change. I thought that was very strange since the car had 7 miles on it but they said that from production date to delivery date it has been a full year and BMW calls for an oil change. Crazy
2017 650i GC xDrive Black Sapphire Metallic, Cognac Leather Interior, M Sport Edition/ Package, 20' Wheels, Driver Assistance Plus, Harman Kardon, Apple Carplay
08-18-2015, 02:31 PM | #2 | |
Rep 592
08-18-2015, 06:03 PM | #3 |
Rep 194
that's funny...i had the exact same things. added 2 quarts just a few thousand miles in, which slightly freaked me out a bit, but figured it was breakin period.
and my center lock was also busted and quickly fixed. prior to that was the drivetrain malfunction, which was not resurfaced. did your rear tow cover pop off too? |
08-19-2015, 09:40 AM | #4 | |
Rep 73
02-23-2016, 08:40 AM | #5 |
Rep 59
I just had this happen to me at 2500 miles...i was bugging for a sec but i just topped it off with 2 quarts. Glad i'm not the only one this happened too.
2016 650i XDrive Gran Coupe MSport Alpine White
Location - Brooklyn,NY IG- SnowBlanca_F06 Add Me |
02-23-2016, 09:12 AM | #6 | |
Rep 3,968
edit... just add "fully warm up car...then bring to redline
02-23-2016, 11:25 AM | #7 |
Rep 592
I don't even do that. I just start them up for a few and drive off the lot in 1st to redline somewhat slowly and then just let the engine slow me down about 3 times in a row and then drive the car like a beast from then on. My BMW's have never needed oil added like I have seen others. Could be luck, or the break in.
02-23-2016, 01:46 PM | #8 | |
Rep 3,968
http://www.mototuneusa.com/break_in_secrets.htm
02-23-2016, 02:05 PM | #9 |
Rep 144
i had to had 2 qts at around 5000 miles. i just added oil myself, closest dealer to me is at least 30 min away. i just bought oil and poured it in, saved myself the time and bs of having to go to the dealer just to top up.
02-23-2016, 02:20 PM | #10 | |
Rep 592
02-24-2016, 07:06 AM | #11 | |
Rep 59
02-24-2016, 01:11 PM | #12 |
Rep 592
All they are going to do is top it off. I would just buy a couple quarts and keep it in the trunk and do it yourself to avoid the dealer. Either your car has some loose piston rings and eats a good amount of oil, or they didn't fill it full the first time around since it happened at 2500 miles. I don't see them replacing the engine for oil consumption, but that would really be the only solution.
02-25-2016, 07:00 AM | #13 |
Rep 73
I have not had the issue since it first occurred. They topped it off and the car maintains good levels now. 9K miles and no issues...
02-27-2016, 09:54 AM | #14 |
Rep 3,968
BMW considers a quart every 1,000 miles "normal" I believe.
As in "cheaper to give you a lot of oil than rebuild the engine "
05-16-2016, 10:45 PM | #16 |
Rep 95
The N63TU engine has a giant oil sump, 9 liters for an oil change. Add 1.5 quarts if you get the low oil warning and check the level 800 miles later.
Right now my 650i is half way between full and low on I-Drive, going to add a quart in the next day or two. My 650i goes through a quart every 4-5K miles. Actually gives me something to do.
2013 650i Red Imola Coupe N63TU - Original Owner Delivered 10/2012
M Sport - Individual Leather Merino Opal BMS JB+ Stage 1-96 Octane-VR Power Pedal-Dinan Shockware 20” 373 Wheels--Hankook Ventus V12 Evo2 Summers/ RIP RFT M6 Spoiler-Full LED Last edited by ShakeDaddy; 05-16-2016 at 10:51 PM.. |
