08-03-2015, 10:56 PM | #1 |
Rep 89
Performance Increase
Question... I have a 2014 M-Sport GC. Considering a BMS intake and JB4 addition. What should I expect from a power increase??? Will it be relatively minor or significant like driving in Sport mode??? Thanks.
08-04-2015, 04:25 AM | #2 |
Rep 89
My coupe has Dinan Stage 1 and shockware and sprint booster for the throttle lag and because of the way these cars are geared if you want to really feel the power increase you will have to use the paddles. These are heavy cars that shift too low in the RPM range (even in sport) to fully enjoy the power band. I am sure since they are seen a luxury coupes (and to save gas) BMW does not design them to shift at 6000 RPM
08-05-2015, 12:38 AM | #3 | |
Rep 536
08-05-2015, 05:54 AM | #4 |
Rep 89
I own two 650's coupe and convertible, and have driven at least a dozen, not a single one of them did that. My Panamera is the exact same way, you need to use the paddles to control the power band.
08-05-2015, 01:48 PM | #5 |
Rep 592
I would argue that is completely incorrect. The car is fastest and most consistent in Sport+ S mode. It's also the only mode you can use the launch control feature in. I see that your car is modded, have you activated launch control?
08-05-2015, 05:49 PM | #6 | |
Rep 63
08-06-2015, 04:09 AM | #7 |
Rep 89
No matter what mode I am in the car will not go to redline on its own I have to use the manual controls and the paddles if I want it to go to redline. Yes I had no problem getting the module behind the pedal in fact it was the quickest install of one of these I have ever done. I own a lot of cars and the 650 is one of my cruising cars I do not need to use launch control with this car
08-06-2015, 11:56 AM | #8 |
Rep 89
Thanks for the responses. Anyone with a 640 that installed the JB? What performance changes did you notice? I have read the info on the website but I would like to hear real experiences with a 640. The 650 is already significantly more powerful than the 640 so the comparisons are not Apple to Apple. Thanks
08-06-2015, 01:12 PM | #9 | |
Rep 592
08-07-2015, 08:41 AM | #10 | |
Rep 536
I made a video for you (pardon the music ) http://tinypic.com/r/28riqhe/8 |
08-07-2015, 01:27 PM | #11 | |
Rep 592
08-08-2015, 03:24 AM | #12 | |
Rep 536
Anyway, OP, the JB4 from BMS is a tested, proven ~30whp increase on an N55 engine, not sure about the N63Tu but it should be a smidgen more. As far as bang for buck mods go, it's hard to beat, and it scales very nicely if you decide to add other performance mods too. I'd say definitely go for it. |
08-08-2015, 11:41 AM | #13 |
Rep 89
Thank you. I don't have any experience with mods. I've always been skeptical about adding non-OEM parts to the main components, especially BMW's.
08-08-2015, 09:22 PM | #14 | |
Rep 3
When would u say is the best time to shift if not redline? I was always under the assumption you were suppose to redline it? |
08-08-2015, 10:24 PM | #15 |
Rep 592
If you're shifting manually, somewhere between 6000-6500. When things are moving that fast just make sure you're keeping both eyes planted on the road! This is ARC550's dyno in his 550xi with a tune and 93oct. His car is a beast by the way! You can see on the graph that by the time you're crossing 6500 the curve is already down around 70whp from peak and dropping.
08-08-2015, 10:50 PM | #16 | |
Rep 327
For the 650i (with the N63Tü engine) max horsepower comes at 5500 rpm, and gradually drops off until redline at 7000 rpm. |
08-09-2015, 01:44 PM | #19 |
Rep 592
Right, but you don't want to shift at 5500rpm because once you go into the next gear you'll be too low in the RPM range. Shifting at 6500 will keep the RPM's bouncing between 5000-6500 and keep the car pulling hard.
08-11-2015, 05:43 AM | #20 | |
Rep 89
Thanks for the video, and my car is going in because it will not do that on its own. I have been a member of many forums over the years (my name here is the title of my first novel) and this is the very first time I have been called a troll. You can find my posts on Ferrarichat (been there since 2003 one of the old timers)as Carnut, I am 1Carnut on Rennlist and I also belong to 6 speedonline, Bimmerfest (Rich the coder has seen some of my cars)and the 500 Abarth forums. If my statements offended anyone I do apologize but you will see if you chose to look that everything I have stated is true.
08-11-2015, 06:05 AM | #21 |
Rep 89
If you want to take an easier route go to mikesultraservice.com you can see a few of my cars including Mike in front of my 430 coupe, my Gallardo (before it was transformed) my 07 Z06 my white M6 and coupe of my Porsche's including the superchargered 997S and even my Abarth. After over 40 years of doing modifications to cars I am not a hyped up about it (or as interested as I once was) but being called out as a fake, well that is a very different story.
08-11-2015, 04:57 PM | #22 | |
Rep 592
