08-25-2023, 12:36 PM | #1 |
Rep 106
To hone or not to hone?
I recently switched out my stock downpipes for cattless downpipes, and now I have white smoke coming out of the exhaust whenever I'm idle. When I had the stock cats on, I'd only see the smoke if I idle for like 10min and then give it a hard rev.
I tried some oil additives to recondition the valve seals and it worked great until I did another oil change. So it was only masking the issue by thickening the oil and it didn't really solve anything. I decided to have the valve seals replaced. Dropped off car at the mechanic and he went one step further and removed the heads. The drivers side bank cylinder walls have some scratches which he thinks have been caused by bad piston rings. The passenger bank walls are pretty much fine with no scratches. If you run your fingernail over the scratches you can feel them. Fingernail doesn't get stuck/caught in them though. Mechanic is saying we can have them polished/honed without having to go to oversized pistons and rings. My understanding though is that these alusil blocks are difficult to hone and so I am wondering if I should just change the piston rings and rod bearings and don't recondition the walls? safer? The interwebs seems to say that replacing the valve seals should resolve the white smoke issue. And I'm wondering how much difference I'll actually benefit/feel by honing the walls.. What do you think? |
08-25-2023, 02:47 PM | #2 |
Rep 2,907
That's probably a question for an experienced engine rebuilder. Only real-world experience can tell you the effect of scratches like that. But question one is how many miles does the car have and how long are you planning on keeping it? And question two is how much will he charge to do it?
08-26-2023, 03:09 AM | #3 | |
Rep 106
So my mechanic will send off the cylinder heads to a specialist to press in new valve guides (because there is too much play in the valves and new seals would wear quickly again) and recondition the valve seats for $550. He reckons he can get the guy to polish the cylinder walls for no extra cost So strange that the scratches are only on the driver's side. |
08-26-2023, 06:49 PM | #4 |
Rep 639
I would definitely hone while it’s all apart. I would worry that the damage will only grow if left as is.
