02-21-2016, 01:21 PM | #1 |
Rep 647
akra drone myth
I've had turner muffler deletes, to me the sound was amazing, really aggressive on downshifts, to some (my gf) it was a little too loud so I decided to switch to akra, and it does have a beautiful tone to it, it's made absolutely beautifully and even though it may not be as loud as turner, with the downpipe it's enough, sounds is great however during the highway cruise with ctless downpipe both exhausts have the same noise in a cabin, not the most pleasant noise and switching to a much more expensive akra didn't change a thing, idk how other exhaust drone probably meisteshaft is really bad, but turner and akra both with dp's cabin noise is the same, there's definitely always humming noise, just sharing my own experience who thinks it's otherwise.
02-21-2016, 02:19 PM | #2 |
Rep 170
It must be the down pipes because I can tell you my Akra system has Zero drone on the highway with stock cats. I want to hear more turbo spool and I am considering down pipes now but I do not what drone or throw codes.
02-21-2016, 03:13 PM | #3 |
Rep 620
You may want to look into having your active sound coded off. When cruising the active sound does make a humming sound, and it may help or solve your issue for very cheap or free if you or a friend can code.
2014 911 Carrera S - White/Two Tone Espresso/Cognac - Aerokit Cup...
2013 F12 M6 - AW/Black Merino - Loaded 2018 F150 XLT Sport - Lightning Blue/Black Cloth - 5.0 V8 4D/4WD... |
02-21-2016, 09:47 PM | #4 | |
Rep 737
As I am a Dentists and hear high pitch noises all day, any drone kills my ears ... I have no Drone what-so ever with my set up and Princess only goes out if the weather is good and she is topless (excibitionist tramp ) ... I drive 28 Km each way to and from work and half of that is highway doing 110 km/h ... Perhaps it may be the set up with downpipes ... I am running SuperSprint Catless ... what are you running? Also, are you a hard top? Hoping to be of assistance
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV Past Cars: 2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban |
02-21-2016, 10:18 PM | #5 | |
Rep 170
02-21-2016, 10:39 PM | #6 |
Rep 737
surprisingly ... CEL is only occasionally on.
I'd say about 80% of the time the CEL is off ... running Shell 91 V-power here in Canada if worried, you could always to the high performance catted downpipes ...
Current Garage:
02-22-2016, 08:27 AM | #7 | |
Rep 737
Current Garage:
02-22-2016, 09:10 AM | #8 |
Rep 427
Drives: 2019 M5 Competition
Seconded about making sure you disable active sound! With non-standard exhaust, it makes a "drone".
02-22-2016, 11:42 AM | #9 |
Rep 647
I gotta check that out
02-22-2016, 03:34 PM | #10 |
Rep 170
I guess I was under the impression when the light is on it affects how the computer maps the fuel???? If its just a flipping light on the dashboard its no big deal
02-22-2016, 09:57 PM | #11 | |
Rep 737
Hope this helps!
Current Garage:
