      03-18-2014, 11:45 AM   #1
Low Country Larry
Drives: 2015 650i Deep Blue/Cinn Brown
Active Cruise Control retrofit on M6?
Hoping someone has knowledge or can refer me. Traded up to my M6 from a 650 which had the awesome "radar cruise control." Now I believe that's BMW Option 5AT ACC Stop and Go + Active Driving Assistant, which I've read replaces 5DF Active Cruise Control and includes approach control warning with full braking.
But can't be ordered on the M6, even non-manual. Any ideas about retrofitting this incredibly helpful option? Thanks!
      03-18-2014, 12:51 PM   #2
yodicken
Drives: 2008 M3 Graphite Metallic
Same question. I have a call into BMW USA. They were unable to answer why it's not available but claimed they'd look into it. No touch iDrive either. Are they throwing in the towel until the refresh?
      03-18-2014, 02:14 PM   #3
RichardP
51
2013 BMW M6 Gran Coupe  [10.00]
1980 E26  [10.00]
2003 BMW M5  [10.00]
When the E60 was new you could only order active cruise control if you also had the M-Sport package. The reason given was that the sensor(s) required for the Active Cruise control restricted the airflow too much with the standard bumpers and could cause over heating. I suspect a similar reason might apply to the M6 which already has fog light delete to aid cooling.
      03-18-2014, 02:15 PM   #4
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
iDrive touch controller is included on all M6 built from 1st March on.
      03-18-2014, 02:40 PM   #5
m6gcjekyl
Drives: m6 grancoupe 2014
I wanted active cruise control with M6GC but BMWUK confirmed that this could not be fitted because of the impact the ACC sensor had on air flow for engine cooling.
      03-18-2014, 09:17 PM   #6
VintageFerrari
Drives: E39 S3
Have you heard whether this might be successfully retrofittable to pre-Model Year 2015 M6s?
      03-19-2014, 02:56 AM   #7
RichardP
51
1980 E26  [10.00]
2003 BMW M5  [10.00]
Someone here did it, so I'd guess it's possible!
      03-19-2014, 03:10 AM   #8
A_
A_'s Avatar
258
Drives: M8, G70
It's possible and simple but only for MY2014 - iDrive touch controller / control unit + coding
      03-19-2014, 01:12 PM   #9
zoltans4
Drives: '14 650 coupe
its because of the bumper, not that your couldn't retrofit, but.....
      12-13-2017, 03:57 AM   #10
J. Dub
Bob Saget
J. Dub's Avatar
Drives: 2010 335i e92 N54 A/T
Source? Link? Was it retrofitted on a 650i or an M6?
In memory of Robert E. Flynn (AR)
