03-02-2018, 10:47 AM | #1 |
Rep 149
Weird ticking noise !! (Video added)
Hi ,
I recently keep hearing weird ticking noise sometime in idle when the car is cold , also while cruising in 1500-2000 rpm . I went to the dealer trying to figure out the issue , and every time i go there the noise disapears !!! Had anyone been through this issue ? Anyone can help ? Video : https://youtu.be/8Zfj9bkFXGI https://youtu.be/TJrsdroDzxA https://youtu.be/EDaYg5TGyDQ Last edited by aann; 03-31-2018 at 11:42 AM.. |
03-02-2018, 11:04 AM | #2 |
Rep 804
Sounds like wastegate rattle to me, but it could be a million other things. The fact that it is there when it is cold and then gone when it is warm makes me think it's the wastegates. You need to leave the car with the dealer overnight so they can start it cold.
03-02-2018, 11:30 AM | #3 | |
Rep 149
03-20-2018, 04:01 AM | #4 |
Rep 149
Maybe this noise can be a wastegate rattle or maybe something else !!
I dont have aftermarket downpipes ! but i do have akrapiviovc exhaust which apearently can cause this rattle ! I did some research in the forum , but i didnt find any solution for this rattle . Is there anything that can be done to solve this problem ? Last edited by aann; 03-20-2018 at 05:19 AM.. |
03-20-2018, 06:23 AM | #5 |
Rep 355
Have you checked to make sure the exhaust isn't what is rattling? Get under the car when it's cold and shake the system. I had that issue with the tips on my milltek system in a S6.
03-20-2018, 06:35 AM | #6 | |
Rep 149
The sound is like metal ticking noise thats that i hear when i drive in a narow closed places . |
03-30-2018, 12:52 AM | #7 |
Rep 1
Weird ticking noise
That noise is your clutch fly wheel it needs to be replaced I got mine replaced and the reason why I say this is cause that’s the noise I was wetting and the noise goes away when throttling over 2,500 rpm they will most likely need to drop your tranny
03-31-2018, 04:51 AM | #9 | |
Rep 149
Did you here that noise all the time ? Cause mine is not constant , somties it desappears !! Last edited by aann; 03-31-2018 at 05:13 AM.. |
04-16-2018, 07:05 AM | #10 |
Rep 149
Update for the weird rattle that i had which apparently was a wastegate rattle .
i replaced the gasket between the midpipe and the downpipe , and also i replaced the gasket ring , no more rattle anymore i have to say again that i had the stock downpipes , but when the akrapovic exhaust was installed the gasket should've been replaced too . very happy that the rattle is gone , it was very annoying and i was embbarassed evrey time i was driving slow with low rpm's in the hood . Here's some pictures : Last edited by aann; 04-16-2018 at 07:42 AM.. |
06-04-2018, 05:39 PM | #11 | |
Rep 291
06-04-2018, 09:03 PM | #12 |
Rep 149
RichardCranium28.00 |
06-05-2018, 11:14 PM | #13 |
Rep 291
