      11-21-2017, 10:15 AM   #23
Flying Ace
Flying Ace's Avatar
4985
Also, you won't have the touch function just doing this swap correct?
      11-21-2017, 07:51 PM   #24
Evil Derboy
Evil Derboy's Avatar
Drives: E92 M3
Not from swapping the screen alone. Although I do have it as I swapped out the new controller , added the touch ECU and coded it in so it is possible.
      11-22-2017, 01:46 PM   #25
Flying Ace
Flying Ace's Avatar
4985
ok, as I suspected, you need the new head unit with the ECU to get touch functions.
So what do you think? Is touch worth it? I've had a few loaner cars from the dealership that had the touch controller. Aside from zooming in and out of the map (which I still think is easier turning the wheel), and writing characters to look up phonebook (which I still think is easier just toggling with steering wheel buttons), what else is new and awesome with touch function?
      11-22-2017, 05:43 PM   #26
Evil Derboy
Drives: E92 M3
If you have an older car with CIC then you need a new head unit. If you already have NBT like me then you do not.
Not much to gained from touch other than what you've already quoted above but as it was only about £60 for the additional ECU and wiring I thought I might as well do it for completeness.
      11-25-2017, 11:44 PM   #27
Flying Ace
Flying Ace's Avatar
4985
So I would still need a ECU and wiring if I already have NBT? Can you post the part numbers?
      11-26-2017, 04:52 AM   #28
Evil Derboy
Drives: E92 M3
I’m not sure if we’re getting crossed wires here. What exactly do you want to achieve?
      11-26-2017, 06:26 AM   #29
Taheemr
280
Drives: M6 GC
Touch function is frankly a waste of time, you have to have the dexterity and accuracy of a wasp to be able to use it, voice command is far more intuitive in my view.
Flying Ace4984.50
      11-27-2017, 12:52 PM   #30
Flying Ace
Flying Ace's Avatar
4985
haha, I think we've been confusing each other.
I just want to confirm:
1. Whether my 2014 M6 (yet to be delivered) has NBT - as of today looking at the navigation screen and comparing it against my CIC screen, it appears so
2. Whether simply adding the NBT touch controller will add touch function without coding - it appears to be "no".
2a. If no, then what else do I need to add the touch function?
3. whether touch is really worth it for the cost of retrofit - my initial take is: "likely no".
      11-27-2017, 02:55 PM   #31
Evil Derboy
Drives: E92 M3
1. Mine is a 2014 and has NBT so I’m guessing yours will.
2. No. Coding is required. The iDrive needs to know that touch is enabled so needs to be coded to show the touch options in settings and in the text entry screens.
2a. IDrive Touch controller + Touch ECU + wiring harness (very simply harness that splices the existing cables between touch ECU and controller). These parts are readily available on eBay if you search for them.
3. Upgrading the iDrive controller for looks alone is worth it in my opinion and after that it doesn’t cost much to add touch. I disagree with previous comments regards usability as I find it pretty good but have to agree that I don’t use it often. In my view changing the screen to the newer OLED version is a much better value upgrade and requires no coding either.
Hope that helps
Flying Ace4984.50
      11-27-2017, 03:12 PM   #32
Flying Ace
Flying Ace's Avatar
4985
Hope that helps
This is a very useful discussion for me. On question 2a, can you confirm you don't need a new center console and that a touch idrive controller will fit into the CIC controller's slot?
Also on #3, so if I simply upgrade the OLED screen and the plastic housing that you discussed earlier in the thread, is there any coding needed? Or it's just plug and play?
Does the image gets stretched? I'm afraid it's akin to watching TV/movies designed for 480p 4:3 aspect ratio on a 1080p 16:9 aspect ratio.
      11-27-2017, 05:16 PM   #33
Evil Derboy
Drives: E92 M3
New iDrive controller fits into the existing slot. No new centre console required.
OLED screen is plug and play. No coding required. Aspect ratio is unchanged. Looks exactly the same except a much brighter and punchier image and a more modern style of screen.
      11-27-2017, 05:34 PM   #34
Flying Ace
Flying Ace's Avatar
4985
thanks..but ehh...not sure I'm willing to spend hundreds on a minor screen update without going through and getting the full touch functionality.
I think I'll wait until the 6er goes out of production and a few used sets (that's not from Europe) come on to the market.
      11-27-2017, 07:13 PM   #35
Evil Derboy
Drives: E92 M3
Lol. I’m not trying to sell the idea to you. Do what you like! FYI I got a used screen for £200. Touch controller was £110 and touch ecu and harness was £75. All from eBay. I rarely use touch and many who have it will tell you the same.
      11-29-2017, 03:11 PM   #36
KauvSTi
Super Member
KauvSTi's Avatar
129
Drives: M6, M8 Comp, S63, 720S, F8
Any cic guys in here doing this upgrade?
      12-24-2017, 01:49 AM   #37
Flying Ace
Flying Ace's Avatar
4985
Since you also swapped out the idrive controller, do you have any step by steps on how to take the center console off?
I'm going to try to swap that ash tray for a cupholder
      12-24-2017, 10:43 AM   #38
Evil Derboy
Drives: E92 M3
I used this: http://www.6post.com/forums/showthread.php?t=1081541
Flying Ace4984.50
      12-24-2017, 11:24 AM   #39
Flying Ace
Flying Ace's Avatar
4985
Thanks! Since I'm doing the ashtray, I'm now thinking of swapping the idrive controller to the NBT touch version as they're only $150 online. I'm going to think about do the full EVO retrofit later, but do you know if the controller itself will be fully functional on the original NBT software with no coding?
      12-24-2017, 02:09 PM   #40
Evil Derboy
Drives: E92 M3
No. There’s coding required to enable the setting of touch functionality in the iDrive menus. You end up with a new entry for “Touch” in the iDrive Settings menu.
I looked at retrofitting Evo but was told that all connected drive functionality would be forfeited.
      12-24-2017, 09:17 PM   #41
Flying Ace
Flying Ace's Avatar
4985
Sorry, I meant if I don't need touch function, but just use a touch controller, will it still work, absent the touch features, without coding?
      12-26-2017, 12:21 PM   #42
Evil Derboy
Drives: E92 M3
Yes. Straight swap and works out of the box.
Flying Ace4984.50
      12-28-2017, 11:19 AM   #43
Duff Ace
Adam
Duff Ace's Avatar
Drives: Lusso, GT3, 360, Vaquish, bike
This thread is interesting.
My car was built Sep 2013...so I assume I have the old screen. I definitely have the old I drive controller.
I can't seem to find a screen online for a price even remotely close to what you said earlier.
Also, can someone post a link to the new controller
      12-28-2017, 12:22 PM   #44
Flying Ace
Flying Ace's Avatar
4985
Contact BPM Motorsport or bimmertech, nothing on their website, but they'll customize a set for you. Or they might have piece it together and they'll sell you the harness and coding.
