06-12-2015, 04:30 PM | #1 |
1767
Rep 7,652
IND | S63tu BMC High Performance Filter Set
The BMC high performance air filter for the S63 is designed and manufactured specifically for the factory air box. The result is a tight fitting filter that is a single piece of plastic, ensuring your filter does not prematurely break. The filter itself is designed to reduce the amount of contamination entering your vehicles intake system while providing increased air flow over factory. BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity.All BMC air filters are pre-oiled, and they can be washed and regenerated by using the appropriate BMC regeneration kit. BMC FILTERS ARE IN STOCK AT IND Available for purchase on the IND website or direct with an IND representative. http://ind-distribution.com/ind/bran...ir-filter-1015 Email: info@ind-distribution.com Phone: 866-963-4520 (local 847-963-4520)
10-27-2017, 05:12 PM | #2 |
BMW obsessed
9587
Rep 10,878
