      01-19-2015, 03:32 PM   #1
Nagromalg3
Drives: 640d MSport
Camera Questions
Hi everyone.
I am picking up my newly purchased 6 series at the end of this week which includes the surround view as one of the options. Im curious to know if its possible to activate just the cameras on the mirrors in order to view curbs around tight corners when moving forward?
Also, I have the front camera for high-beam assist, how easy would it be for BMW to activate Lane Departure Warning? Would it just be a simple code? I really only want the visual warning and don't mind whether my steering wheel lacks the servos for vibration.
thanks in advance
      01-19-2015, 04:50 PM   #2
Bönz
Bönz's Avatar
Drives: 2018 M5
In response to your second question, I am only speculating, but it's an educated speculation, that this would be impossible. You cannot code the LDW without all the hardware in place. The system would fault. If your car isn't factory equipped with LDW, it doesn't have the switch, mirror light, servo (as you mentioned) and who knows what else. I think you're SOL.
      01-19-2015, 06:39 PM   #3
Nagromalg3
Drives: 640d MSport
Thanks for the reply
I should have been more clear, all I wanted was the Lane Departure Warning for crossing over road lines and not the Lane Change Warning (as I thought the mirror lights you're referring to were only blind spot warnings?). I have read that the steering wheel warning can be circumvented by disabling that function and the system can be kept always on to avoid the need for a button (but this was on an F10). Anyways, my steering wheel has the heating function, so wonder if it includes the servos :/
Sorry, I'm not sure what al these BMW acronyms mean, what is SOL?
Thanks
      01-19-2015, 07:37 PM   #4
Bönz
Bönz's Avatar
Drives: 2018 M5
I still don't think it's possible. The wheel with servo is a different part number than wheel with heat, so you don't have it. SOL= ___ out of luck.
      01-20-2015, 06:35 AM   #5
Nagromalg3
Drives: 640d MSport
I see, okay thanks for thei nfo
      01-20-2015, 09:20 AM   #6
SpokenHands
Certified Car Nut
SpokenHands's Avatar
94
I have a 640d equipped with Surround View.
You can activate the cameras in the front fenders (just ahead of the wheels at the 2 o'clock position) to see around corners while merging into lanes. This view is not available at speed.
Likewise you can activate only the rear park-assist camera by itself. The other 2 cameras in the side mirror are for Surround View (top view) and cannot be activated individually.
Surround view appears to work at low speeds and parking speeds under 15mph
Hope this helps.
Ananda
Current: 2018 Range Rover Velar First Edition D300 HSE + 2018 AMG GT-C Coupe + 2013 6 Series BMW GranCoupe (October)
Retired: 2016 AMG-GTS Coupe, 2013 & 2012 Maserati GranTurismo MC Stradale,2016 3-Series Touring, 2009 5 Series GT, 2007 BMW M5, 2012 & 2006 BMW 1 Series
      01-20-2015, 10:02 AM   #7
Nagromalg3
Drives: 640d MSport
Thanks for the info
it's too bad the cameras on the mirrors cant be activated on their own, would be helpful when negotiating tight roads. Range rovers can do this going forward and and call it curb view, hopefully BMW can release an update to do this sometime too
      01-20-2015, 05:40 PM   #8
SpokenHands
Certified Car Nut
94
You have an excellent kerb view around tight corners from the top surround view. In fact it's better than the rangie.
      01-20-2015, 11:32 PM   #9
WWnyc
Drives: 2014. 640 ix Vert
And these can be coded to use at speed.
      01-21-2015, 10:05 AM   #10
Nagromalg3
Drives: 640d MSport
Im sorry, think i may have misunderstood. So are you guys saying i can use the top surround view whilst slowly going forward? As it's not very likely I'll want to reverse up a tight windy car park to activate surround view xD
Because the sales person told me it would only activate in reverse.
Thanks in advance
      01-21-2015, 12:21 PM   #11
WWnyc
You'll need to find a " coder " who can change that and so many other things to help you enjoy the car even more.
      01-21-2015, 12:55 PM   #12
Nagromalg3
Drives: 640d MSport
Thanks. Do you know if that'll void my warranty? Because if it does I'd rather not risk it :/
      01-21-2015, 01:05 PM   #13
aahmichael
Drives: 2015 650ix GC
It activates automatically in reverse, however, you can activate it manually in forward. I use it going forward every time I pull into my garage, or any other space for that matter.
      01-21-2015, 01:10 PM   #14
Nagromalg3
Drives: 640d MSport
That sounds ideal I assuming you had it coded like the other person suggested, have you had any warranty issues? How do you go about activating it manually?
Thanks
      01-21-2015, 02:21 PM   #15
WWnyc
No warrantee issues as the software is already in the car.
      01-21-2015, 02:28 PM   #16
Nagromalg3
Drives: 640d MSport
Oh, thats great.
Sorry for all the questions but I have another: Are BMW able to do this or do i need someone with one of those aftermarket type coder machines?
Thanks again
      01-21-2015, 04:59 PM   #17
aahmichael
Thanks
I don't have any coding. This is standard on the car. You just hit the button on the center console.
      01-21-2015, 05:14 PM   #18
Nagromalg3
Drives: 640d MSport
thanks, I'll try that on Friday
the car tester guy said it was just to turn on/off pdc, but they tend to give wrong info
      01-24-2015, 06:05 AM   #19
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
I can confirm that this is exactly how it works and no coding is required. Once activated, either automatically by selecting reverse, or manually on the centre console button, it remains active up to about 15mph.
      01-24-2015, 08:31 AM   #20
Nagromalg3
Drives: 640d MSport
Thanks.
Due to some complications i wont be getting it until Wednesday, more sleepless nights cant wait to play with all the cars features
