09-18-2014, 07:04 PM | #4 |
Rep 452
I just had the AMS Catted Downpipes installed, along with the P3 Vent Gauge, upped the BMS Tune to 5psi and had the Alcantara Steering Wheel installed. MY GOD - This car is a freakin beast now -- it's so INSANE!!!!
Current Garage: *2015 Singapore Grey F06 M6 Gran Coupe (The Beast) *2014 Black Cayenne GTS 958 (Wife & Kids Beast) *2008 Imola Red E60 M5 (My Other Beast) |
09-18-2014, 08:14 PM | #5 | |
riding on rails
117
Rep 655
Brian
09-18-2014, 09:34 PM | #6 |
Rep 647
Getting catted downpipe is the biggest waste of money, alcantara wheel on the other hand is super sexy , how are you liking the gauge ?
09-19-2014, 11:51 AM | #8 |
Rep 647
you will barely get any results, whatever he is feeling, it's just in his head, and the price of catted after market dp is over 2k, that why in my opinion.
09-19-2014, 11:57 AM | #9 |
Rep 135
Just take your cats out and use a very large chisel to destroy the cells . Many have done it on GTR , Supra's and I believe the Singapore member has done it aswell.
Catt'ed Dp will let more flow through yet keep the engine light under control and fall under emissions level in certain countries . |
09-19-2014, 12:44 PM | #10 |
Rep 1,125
I've heard that the decatted DPs don't create enough back pressure, so there's excessive waste gate chatter from the turbos. Any experience with this?
09-19-2014, 12:49 PM | #11 |
Rep 647
You don't need no back pressure if you're running higher boost
09-19-2014, 03:32 PM | #12 | |
Rep 664
BMS is not resolving that issue. Upping the boost does not fix that either. A catlless exhaust system performs lower on a dyno then a engine with a stock exhaust. Seen it done back to back many times |
09-19-2014, 03:41 PM | #13 | |
Rep 647
It needs time to adopt
09-19-2014, 04:06 PM | #14 |
Rep 792
+1
Adaptation is the key! When I cut my muffler off the car had no power like I lost 4 cylinders. If I would have dynoed the same day it would have shown loss if power tremendously. After the car adapted it was a beast Full torque and in 1000rpm sooner and power across the board. Same with catless DP power across the board and coming in earlier. Test need to be taken at least after a week to make sur car has adapted fully especially for a change like that. Making some catless DP right now and hoping to take care if the cel using my M5 as test mule hopefully will work like my past cars Once I have ready for install will Dyno before and after adaptation |
09-19-2014, 04:47 PM | #15 |
Rep 452
I'm running 100 octane all the time now.
09-19-2014, 04:51 PM | #16 |
Rep 452
I completely disagree. Huge difference. 400 cell vs 200 cell is without a doubt much better. I also got mine used, so they were actually cheaper than catless DP's.
09-19-2014, 06:43 PM | #17 | |
Rep 611
But now I'm using SS catless DP n got the CEL light even with 2 extended micro CATTED bung. |
09-19-2014, 07:00 PM | #18 |
riding on rails
117
Rep 655
Anything that flows better is going to yield better performance. I would have to see for myself a Dyno run with OEM catted vs Catless to truly believe the catless loses power.
Brian |
09-19-2014, 07:33 PM | #19 | |
Rep 664
M6 Gran Coupe with GT Haus full catless exhaust system with no tune VS M6 Coupe completely stock. Both are forum members here. The stock M6 out performed the Gran Coupe back to back dyno runs. Same dyno, operator, fuel, etc.. LSM is the forum member with the stock M6 coupe. He made a post on here and its somewhere back in the list. His posts even states that we went with the Gran Coupe and he posted the numbers for everyone to see. It didn't blow it out of the water insanely but it was enough to think twice about spending thousands of $$$$ Now, I love aftermarket exhaust just like the next guy. Just my opinion on dyno results of the current topic |
09-19-2014, 11:29 PM | #20 |
Rep 452
100% agree. Is it as good as catless? Of course not, but once you compare the 2 downpipes (OEM vs Catted) and have them side by side and look at the cats themselves, it's so obvious that the AMS catted DP's flow better than OEM.
