      03-01-2015, 12:43 PM   #1
56bigblue
Drives: 2014 650i x convertible
Replacing Kidney Grills
Is there any truth that you can simply grip and rip the kidney grills out without damaging the mount for replacement? I've seen several people post that that's the easiest way to do it but do not want to try it and risk damage until I get some confirmation first. Thanks people
      03-01-2015, 12:59 PM   #2
yipyip99
Drives: 2015 F13 Coupe
I did it myself. It's a pain in the ass, but I was able to do it without breaking anything.
Remove the torx screws from the top part of the bumper and you have to pull it out enough to stick your hands in and push on the kidney's clips to release the kidney.
Push clip and pull the kidney at the same time. Slowly so you don't break it.
You can see the locations of the clips on the new kidney you purchased.
Good luck! 😊
      03-01-2015, 01:00 PM   #3
yipyip99
Finished product.
      03-01-2015, 02:18 PM   #4
Downfourit
Drives: M6 Gran Coupe`
No, do not grip and rip anything on a 6 series! I have heard that may work on other models, it will not work here. You have to do like above says with the top Torx bolts and I would mark them with some chalk or you will have to align the bumper to the hood, that's also easy but with the chalk you wont have to. Also there should be some washers under those Torx bolts like spacers, be careful that they don't fall into the engine bay.
      03-01-2015, 07:48 PM   #5
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
The proper way is to remove the bumper - I know others have figured out a way around this, but that's the official BMW recommended way.
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      03-01-2015, 08:32 PM   #6
jwblack750
MBACPA
Drives: 2014 640xi Gran Coupe
I've done two grilles now - F10 and F06. I tried the grip it and rip it technique on my F10, and it worked on one side. The other side wouldn't budget, and I was afraid of scratching or breaking something, so I ended up taking a hacksaw to it. Sounds crazy, I know, but it's the easiest way to do it, imho. Sure, you can't use the OEM grille afterwards, but who cares? I could maybe sell it online, but I'd rather ensure NO damage to my car than make $100.
Anyway, you just cut the slats out, and then you can reach the clips easily. It also gives it plenty of play to pop out more easily.
      03-01-2015, 08:59 PM   #7
troymi
Drives: '15 M235i Convertible
Anyone have a pic of coupe in carbon metallic with OEM performance grilles? Just got mine and thinking of a change, but would like to see a few pics first. Thanks.
