      10-28-2013, 12:09 AM   #1
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
F13 M6 Coupe Track slips
Went to the track today and did 3 runs. Weather was a crisp 45-50 degrees with a chilly wind blowing at 15-20mph. I had my 21's on and my PSI was stock which is not ideal but I wanted to run it like I drive it. Even though I did burnouts before each run the temp and 15-20mph winds cooled the tires off pretty quickly so there was a little spinning. As you can see from the 60ft times they aren't great so there is a ton of room for improvement. Mind you I'm on 21's too. So considering all this if it was a little warmer out or not so windy and my tires were softer I can easily get the 60ft in the 1.60-1.80 range and the car will easily do 11.40's all day and could possibly go 10.90's-11.30's with less tire pressure or even smaller diameter wheels and slightly warmer temps for better grip. Also a thing to note is that I didn't boost the car at the start....the car has a slight delay after I floor it which affects the 60ft time do to the slight roll that happens that triggers the clock then the power kicks in. So if I boosted the turbos a little by holding the brake for 2 seconds and juice the throttle a bit then letting go of the brake I believe this car can go 10'90's-11.30's. I might even try launch control just to see. I had full traction off everything maxed out with the suspension in comfort. All I did was floor it. No tricks. Here you go. Check out the trap speeds and 60ft times and you will understand the potential. I'm always in the left lane. Feel free to add your slips, info and experiences at the track.
Couple other Nuts
My Thread:
      10-28-2013, 01:17 AM   #2
wzj519
Drives: 2017 M3 COMP PKG
Nice Run. Hunter.
Your m6 is eye catching already and now you are going to do some speed catching staffs.
Super m6 in the world.
      10-28-2013, 05:21 AM   #3
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
Hunter in optimal setup you should be very low 11s range. No traction in cold and hard to heat up the pilot supersports. Cup tires and maybe break into the 10s. Interesting though never saw you as a track guy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      10-28-2013, 01:26 PM   #4
wzj519
Hunter is going to become batman now. Fashion +speed
Omg
      10-29-2013, 05:52 PM   #5
turbo8765
Drives: very fast
Did you calculate the DA?
      10-29-2013, 06:12 PM   #6
Hunter5179
Hunter5179's Avatar
-17 above sea level.... relative density: 100.05%
I'm going again this weekend. This time I will spool up the turbos before I launch instead of just flooring it. Should be easy to get in the 11.4's
So with that correction it the fastest quarter time was 11.603. This was with a shitty 60ft and not spooling the turbos.
My Thread:
      11-02-2013, 09:33 AM   #7
RiverRunner
RiverRunner's Avatar
Drives: 2014 M6 Gran Coupe
Those 60ft times are no surprise. I agree, that's where the biggest improvements are going to come from, I bet launch mode would help fix the R/T and turbo spool. I just would need to practice setting it up so when I'm staged, I can focus on the tree.
2015 740i Sapphire Blk/Blk
2018 Tahoe RST 6.2
2019 Porsche 911 Turbo 991.2
      11-07-2013, 06:54 PM   #8
turbo8765
Drives: very fast
Did you get back to the track? New numbers?
      11-07-2013, 11:44 PM   #9
Hunter5179
Hunter5179's Avatar
It was to cold. The track didn't open. Maybe I will have a chance this weekend.
My Thread:
      01-06-2014, 04:18 AM   #10
SlashM3
Drives: 09 E93 M3 interlagos
Interesting.
      01-11-2014, 12:27 PM   #11
Hunter5179
Hunter5179's Avatar
Omg
LOL. I missed this.
My Thread:
      01-11-2014, 01:04 PM   #12
SlashM3
Yeah man I wish I could get 50 degrees
      01-12-2014, 11:00 AM   #13
SlashM3
By the way u do know the coupe is a F12 right? Lol
      01-12-2014, 04:59 PM   #14
Hunter5179
Hunter5179's Avatar
The coupe convertible is the F12. The non convertible coupe is the F13M6
My Thread:
      01-13-2014, 02:05 PM   #15
SlashM3
No the coupe is F12 and the convertible is F13 A vert in chassis code always has a 3 in it.
      01-13-2014, 05:18 PM   #16
btbossman
Drives: 2013 335xi M sport--2014 M6
Sick!
