02-19-2013, 01:15 AM | #2 |
Rep 881
The body style of the regular 6 and the M6 are the same. So no wider arches/wheel wells. This has been confirmed by a member that retrofitted the M6 bumper F&R on his 650i GC. So I assume the wheels should be no problem at all!
Specs are f 9x20 and r 10.5x20 No idea on offset. |
02-19-2013, 05:08 PM | #5 |
Rep 482
For the M6 wheels, they are:
Front wheels: 20x9.5" ET31 Rear wheels: 20x10.5" ET19 Ya, I know the widths will fit, just want them to be flush (or close to flush) with the fender. Right now i have 22x9 F and 22x10.5 R and they fit fine |
02-19-2013, 06:51 PM | #6 |
Rep 2,404
I would be worried about the rears sticking out too much. Stock wheels are 33 offset in front on 8.5 wide wheel and 44 offset in the rear on 9 wide wheel.
The fronts will be about the same but the rears will be about 1.2 inches further out. |
02-20-2013, 10:39 AM | #8 | |
Rep 10,166
but If my wheels (10.5) with a 19 offset would sit outside of your fenders that means you have a slightly less aggressive fender line.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
02-20-2013, 10:43 AM | #9 |
Rep 2,404
I think it would clear everything. But as Vic55 said, it won't be flush.
If you want them flush there are probably some replicas out there that would work. But I am not sure about the quality. |
09-11-2013, 12:52 AM | #11 |
Rep 2
according to WHEEL OFFSET CALCULATOR
http://www.1010tires.com/Tools/Wheel-Offset-Calculator for Rear Wheels Current Wheel Specs Width 9 inches Offset 44 mm --> 6 GC Wheel Specs New Wheel Specs Width 10.5 inches Offset 19mm --> F12/F13 M6 Wheel Specs Results Inner Clearance: 6mm MORE (the inside of the wheel to the strut housing) Outer Position: EXTEND an extra 44mm (position of the outside edge of the wheel) look like dose not fit same problems here, i am looking for 343m wheels on 6 GC but can not find any information about fitment |
09-11-2013, 11:18 AM | #13 | |
Rep 277
Drives: 2014 M6 Gran Coupe
2015 740i Sapphire Blk/Blk 2018 Tahoe RST 6.2 2019 Porsche 911 Turbo 991.2 |
