      01-03-2019, 01:53 PM   #1
polar993
Legend
49
Drives: 2017 Alpina B6 Gran Coupe
Lowering Springs for Alpina B6 Gran Coupe
Hi,
I am looking to lower my 2017 Alpina B6 Gran Coupe, and I am having trouble finding after market springs that have a direct fitment for my car.
I contacted H&R and they couldn’t guarantee fitment for their springs that fit the F06 M6 Gran Coupe or the F06 605i Xdrive.
Does anyone here know if the springs for the F06 M6 Gran Coupe or 650i Xdrive will fit an F06 Alpina B6? I would think the 650i Xdrive springs may work considering the Alpina B6 is all-wheel-drive.
Any help would be appreciated!
      01-03-2019, 03:37 PM   #2
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
A B6 is a 650ix therefore the springs should fit.
      01-03-2019, 10:47 PM   #3
polar993
Legend
49
Thanks Havy! That makes sense. Unfortunately the spring manufacturers won’t guarantee fitment, but if you and others believe that the springs for the 650i Xdrive will fit the B6, I may roll the dice and order a set.
I know most of you on this board are big fans of H&R springs....I am too, and I have them on my E60 M5. The drop on the H&Rs is 1.2” front and 1” rear. The drop of 1.2” in the front is a bit too much for me. Eibach has a set of springs that drops the front by 1” and the rear by .8”. To me, the Eibach has better specs to suit the look I am trying to achieve.
Does anyone here recommend Eibach springs? Will the ride quality be comparable to the H&Rs? Considering the drop on the Eibach’s is less than the H&R’s, would the ride quality be a bit softer? I know spring rate has the biggest effect, but i don’t believe there is a way to compare spring rates, correct?
      01-04-2019, 03:03 AM   #4
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Eibach and H&R are top notch spring and coilover manufactures. There is no magnificent difference. In the end it is your taste.
      02-02-2019, 03:00 PM   #5
rexpontius
Drives: BMW 650xi GC 2013
I have the eibachs on my 650xi and love them, ride is a bit firmer but very acceptable. Looks / stance is awesome. Just be careful driving over bumps and potholes
      02-02-2019, 04:10 PM   #6
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
Pics or you didn’t do it.
      02-02-2019, 04:32 PM   #7
rexpontius
No problem will make a couple of pics tomorrow (now dark outside )
      02-02-2019, 08:07 PM   #8
polar993
Legend
49
I had the H&R height adjustable springs installed. The final height still needs adjustment....the front is too low, and the rear could be dropped a bit more. I’m going to let it settle over the next few days before making the final adjustments. Adjusting the springs is very difficult as it’s very tight up by the top of the strut. The rear isn’t as difficult to adjust.
The ride quality is very nice and didn’t change too much from the original stock suspension. The ride is about 15% stiffer, but on the comfort setting, it’s hard to tell the difference.
Here are a few pics:
jjasonSU194.00
      02-03-2019, 02:03 AM   #9
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
That looks awesome the front maybe a tad more up. But that is saweet
      02-03-2019, 05:32 AM   #10
rexpontius
Here are some pics of the Eibachs as promised. The first two pics I just took is with the winter wheels (19) on.
The lower pic is from a photo shoot a couple of months back with the 20" Msport wheels on.
Tags
alpina, lowering, springs
