03-26-2015, 11:17 PM | #2 |
Rep 194
i don't know if its truly bad, let alone how bad, but if they came square, probably leave them square.
but, during the summer, i might try staggered if i were in your shoes and see how it goes |
03-28-2015, 06:33 PM | #3 | |
MBACPA
13
Rep 91
I run staggered on my 640xi, and I recall them being 20x8.5 and 20x9.0, and 245/35/20 front and 275/30/20. |
03-29-2015, 05:26 PM | #5 | ||
Rep 66
I have the same tire sizes as you. Only the rear rims are a little bigger. 20x10. I had them on my E90, so they will definitely clear on the F13. I just don't want to mess up the tranny or drivetrain. I was also thinking maybe run the car on sport+ mode which shuts off the awd system and the car becomes a rwd. We'll see... |
03-29-2015, 10:03 PM | #6 | |
MBACPA
13
Rep 91
03-30-2015, 06:11 AM | #7 | |
Rep 324
Drives: 2014. 640 ix Vert
Are you sure? I don't think so 😳 |
03-30-2015, 09:24 AM | #8 |
Rep 764
03-30-2015, 11:16 AM | #9 |
Rep 66
03-30-2015, 11:16 AM | #10 | ||
Rep 125
BMW CCA: 501218
Current owned: 2018 540xi MSport Previously owned: 2015 650xi Gran Coupe MSport 2011 X5 50xi MSport |
03-30-2015, 11:17 AM | #11 |
Rep 66
03-30-2015, 10:58 PM | #12 | |
MBACPA
13
Rep 91
03-31-2015, 07:26 AM | #13 | ||
Rep 66
I know the rims will clear without any problems. My concern is the effects of having staggered wheels on an awd vehicle. Would it kill the transmission or the drivetrain? : |
03-31-2015, 08:37 AM | #14 |
Rep 467
Simple answer: No. BMW offers the X drive coupe with optional staggered 20" setup.
03-31-2015, 10:47 AM | #15 |
Rep 764
12-02-2019, 10:33 PM | #16 |
Rep 15
2015 640ix Staggered Question
I am interested in putting staggered rims on my 6. I have seen a lot of info about it and I know it is possible to do without damaging the xdrive. I am looking at some wheels that are 20" x 9"et35 front and 20" x 10.5"et38 rear's with a 72.6cb. Any idea if this setup will damage anything?
12-03-2019, 01:49 PM | #17 | |
Rep 7,475
BTW...what is the wheel bolt pattern? The f06/f12/f13 six series has a 5x120mm wheel bolt pattern...if you're going to use a wheel with a different wheel bolt pattern, you may need to use some type of adapter...so its dimensions will also need to be added to your calculation.
12-04-2019, 12:37 AM | #18 |
Rep 121
It's quite 'normal' to have mixed sets in the 'show' cars but as said X-Drive does not take much tolerance between front and rear tires, in the end it's the same what charts says other 275/35/19 tire can have bigger outsize than other so it's an risk always.
With X-Drive it would be wise to have same tire in every corner ...... but as many of us I'm riding mixed 245/40/19 front / 275/35/19 rear summer tires. |
