      01-05-2015, 09:34 AM   #1
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
Holy Crap! The Battery is now a maintenance item!
Some of you might have seen the recall notice on the N63 engine (timing chain, injectors, etc.). At the very end was mentioned battery.
Turns out that the N63 and N63tu and I'm assuming the S63 variants now have their battery listed as a "maintenance item". Meaning that at every 2nd oil change, BMW will put a new battery in the car.
Per the dealer, the running of the cooling pumps/fans after the car is shut off, is killing the battery and so as long as the car is under warranty, they will continue to change out the battery -every 2nd oil change.
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      01-05-2015, 11:30 AM   #2
Downfourit
Drives: M6 Gran Coupe`
Nice find! I'll be sure to mention that on the second oil change! My first one is coming up in a couple weeks
      01-06-2015, 12:14 AM   #3
ctenidae
Drives: 2012 650i Coupe- Manual
My lease is about to run up, so I'm most interested in what the incentives might turn out to be.
Not too surprising on the battery thing. Last winter, when it was 15 or less around here for a long time, I had a constant battery problem, apparently related to the battery sensor not operating correctly when it's cold. Since it disabled the heater fan when it read a low battery, there's no telling what it does when any other conditions exist...
      01-08-2015, 09:56 AM   #4
E90Fleet
South Africa
1312
All 90AH batteries area also being changed to 105AH ones for free with this service action.
You can get by with not changing the battery so often if out of warranty by putting the car on a proper charger every few weeks ( example Ctek charger)
This will prevent it from being discharged too much.
BMW if you are reading, I need a job, Please.
      03-15-2015, 11:45 AM   #5
mrjoed2
Drives: '14 650 M Sport Edition
This battery replacement as a maintenance item is very interesting. Was there a bulletin or notice issued to dealers for this? As oil changes are now once per year, We are talking about replacing the batteries at no charge after 2 years.
      03-16-2015, 10:59 AM   #6
Joe Baseball
Drives: 2013 650ix coupe
Current oil change protocols N63tu?
Does anyone know if the oil change protocols have changed for the N63tu engine? I have a '13 650ix coupe, had my first scheduled oil change at 15,000 miles and the dealer reset my "next oil change" for another 15,000 miles. Was curious if that is correct or is it now 10,000 mile intervals as I have heard?
      03-16-2015, 11:23 AM   #7
bravo261
Drives: F06 650
interesting, so the flipside of this perk is that we're supposed to change the batteries every two years once we're out of warranty now? that's kinda crappy
      03-18-2015, 07:56 PM   #8
ShakeDaddy
ShakeDaddy's Avatar
10
Drives: 2013 650i Coupe
Take her back to the dealer and have it reset to 10K. That's the new Oil Change interval, 10K or once a year.
      03-18-2015, 08:13 PM   #9
ShakeDaddy
ShakeDaddy's Avatar
10
Another lesson I recently learned is if your going to not start up your 6'er for a week or so put the car into sleep mode by simply setting the alarm. I do a lot of traveling and the first year of ownership I never set the alarm while being away with the car in the garage, now I do. Last time I was vacationing for 15-17 days and with the car in sleep mode started right up with no hesitation.
      03-18-2015, 08:20 PM   #10
doug_999
doug_999's Avatar
2542
Here is the bulletin
http://www.google.com/url?sa=t&rct=j...,d.eXY&cad=rja
and yes, oil changes every year now or 10K.
