10-31-2016, 03:27 AM | #1 |
Rep 194
Motul 8068HL RBF 600 Factory Line Dot-4 Racing brake fluid
Like to know has any one use racing brake fluid?
I am planning to change my Disc and SS line and also what to try racing brake fluid. I wonder is the Motul 8068HL RBF 600 Factory Line any good on our 640i Msport? https://www.motul.com/system/product...pdf?1340122148 https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
2015 640i GC M Sport
11-04-2016, 03:48 AM | #2 |
Rep 136
I have no experience with the Brake fluid of Motul but for the engine oil, highly recommended....
Not sure if you really do need or a must basis for you to use race spec fluid unless you will track your car... |
11-17-2016, 10:51 PM | #3 |
Rep 751
Drives: 2019 BMW X6M
I personally would stick with regular brake fluid if I am not tracking car. I would use Racing brake fluid only if I track the car regularly which I will never do on my 650i.
11-18-2016, 12:12 AM | #4 |
Rep 194
The items arrived will install the upgrade brakes this weekend and let you know if it dose the job well.
11-22-2016, 12:11 AM | #6 |
Rep 194
Some feed back, did a run last SMD and the brake fluid is good and did the job very well so much better than stock. After draining the old stuff after 1 year it was black, I may have burned it, thats why before change it was very soft on braking.
12-03-2016, 01:38 AM | #7 |
M Master
74
Rep 551
Motuls is good, but there is better..
Castrol SRF is the BEST on the market... Research it... This stuff resists the Highest boiling temps and wet temps among everything else. Used by F1 teams, Rally teams etc... bar none it is the best..Ive tried Many.. Including Motuls. Its pricey though, but whatever.. totally worth it.. They also just released a newer version of their formula, so its up to date and compatible with pretty much everything DOT
M History: E46 M3, E92 M3, E63 M6, F13 M6 Comp Pkg, E71 X6M
12-03-2016, 08:29 AM | #8 | |
Rep 194
