      03-23-2015, 03:29 PM   #1
Jeff73
Drives: M6 Cab
Looking to install the DINANtronics
Anyone have a bad experience with the DINAN install? Also is the performance a significant improvement? Thank you guys...
      03-24-2015, 10:58 AM   #2
LI M6
Drives: 2014 M6 GC
My install was no problem....done at BMW dealer.
No dyno data but car definitely feels stronger, more responsive - especially above 3500 RPM.
      03-24-2015, 11:27 AM   #3
Jeff73
Drives: M6 Cab
Thank you.
      03-25-2015, 10:35 AM   #4
A Frankfurt
Drives: German
The only thing's I can note to make sure that the connectors going to "both" engine control modules are plugged in correctly.
The connectors can easily be mistaken and plugged in wrong which can damage the pins.
Also, pay attention to how the harness gets routed, clear of obstruction.
And last when programming the vehicle, it needs to be within 10 feet of the programming computer otherwise you will loose signal.
The Dinantronics is wireless and needs a strong signal to program.
Have the person programming the unit to make sure after programming that the file is correct.
After that, enjoy the performance.
I have programmed many Dinantronics and each client is more then happy
Get the stage 2. It is a noticeable difference from the stage 1.
I chirp tires shifting into 3rd gear merging onto the fwy
      03-25-2015, 03:02 PM   #5
Jeff73
Drives: M6 Cab
thanks for the advise! Looking to have it done the end of April, when the snow melts
      03-26-2015, 08:36 PM   #6
BTF13M6
BTF13M6's Avatar
Drives: 2013 BMW M6 Coupe
Mines en route. Should install next week
2013 F13 ///M6 Coupe - Singapore Grey
20" ADV.1 5.0 MV1SL with Pirelli Pzero's
Custom Painted Grill, side markers and tinted front reflectors, Dinan Stage 1.
      03-27-2015, 07:08 AM   #7
Majestic
Drives: 2014 Bmw M6
Dinan Stage 2
I had the Dinan Stage 2 ECU Piggyback installed a couple weeks ago.. loving it:
Sorry the graph doesn't show torque.. the torque readings got a little messed up :\
-Matt
2014 BMW M6: Competition/Executive/Drivers assist+/Carbon Ceramic brakes, B&O Sound, Nightvision, Escort 9500Ci w/ laser shifters, AMS Catless DP's, Akrapovic Evolution exhaust, Dinan Stage 2 ECU Piggyback, Dinan Intakes, Full Vorsteiner accents, M Performance steering wheel, carbon fiber shifter, Awron vent gauge.
2017 BMW X6M: In the process of modding
      03-27-2015, 07:10 AM   #8
Majestic
Drives: 2014 Bmw M6
This was with the Dinan Stage 2 Tune, Dinan Intakes, Akrapovic exhaust, and Catless Downpipes.
-Matt
      04-03-2015, 07:52 AM   #9
desant89
Drives: 2012 M6 Convert/2013 Alpina B7
Is there any new information on tuning for the 2012+ M6? I have read this and countless other threads for days now. There are quite a few that will tune the ECU itself, but being under warranty, I will not take that path yet. Dinan seems to not be any different from the other piggyback systems other than the warranty.
Jag from ECU tuning group sounds very convincing when speaking to him, but is his or any other piggyback worth more than the BMS? Just got this car and my tuned 07 sl55 will kill it so I just want this car up to par. Thanks in advance!
      04-03-2015, 10:34 AM   #10
Jeff73
Drives: M6 Cab
Just removed my M6 from storage and each time I realize how much I miss it. Anyway in response to your question, none of the other companies offer a similar BMW factory warrantee. This is the dilemma because others are as good if not better but they offer no significant warrantees.
      04-03-2015, 11:54 AM   #11
speedracerlo
Drives: 2015 M6 Gran Coupe
-Matt
is that WHP?
      04-03-2015, 01:10 PM   #12
desant89
Jeff, thanks for the response. I understand the warranty but you can also remove the piggyback prior to service. I know some frown on that, but dealers to plenty for us to frown upon also. Given that, I am having the toughest time deciding which one (not Dinan) to go with.
      04-03-2015, 03:03 PM   #13
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Personally I would wait for AMS to release their ECU tune. AMS is a very well respected name in the industry and their tune should be out shortly. If you are looking for a piggy back tune Burger/JB4 is the best bang for your buck and can also control/monitor methanol flow as well if you end up going that route.
Brian
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast
      04-03-2015, 03:05 PM   #14
desant89
Brian
I like the thought of the ECU tune direct, but I do not want to deal with the hassle of BMW complaining about it when I bring it in for service, or them resetting it. Burger I would just remove.
      04-03-2015, 10:36 PM   #15
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Yes, I can understand that concern for sure. I was straight up with my dealership when I first purchased the car, let them know I was going to mod it, and asked for their support. They know everything I have done to the car and work with me on everything. I know most dealerships are not like this (from what I have heard) but I prefer to be straight up with people (it's the way I am) because you just never know what they will say.
I also tip the service guys (generously) once in a while which probably helps. The way I see it is if they are helping me out then it's well deserved. You tip a waiter nicely when service is good right? Why not tip the service guys when the service is good? I will say this for sure "It goes a loooooooong way!"
Brian
      04-04-2015, 06:10 PM   #16
VintageFerrari
Drives: E39 S3
AMS is certainly a very good company. Another solid BMW tuner to consider is ESS.
http://f10.m5post.com/forums/showthread.php?t=1109577
http://www.esstuning.com/products/S6...-Software.html
http://www.esstuning.com/productimag...product_id=184
      04-04-2015, 06:41 PM   #17
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Brian
Isn't AMS ECU flash tune already out?
http://f10.m5post.com/forums/showthread.php?t=1080125
      04-04-2015, 07:09 PM   #18
bigbrian
riding on rails
bigbrian's Avatar
Drives: 2o13 m6 f13
Hmm... Well it sure looks to be and I just found the tune on IND (link below). I was on a waiting list with AMS and they were supposed to contact me when it was ready. So much for that /facepalm.
Link: http://ind-distribution.com/ind/ams-alpha-f1x-m6-tune
It looks like there is an option for "AMS Turbos" as the "Turbo Type". I sent IND an email about this because last I heard AMS was 3-4 months out coming up with a tune for their new turbos. If the tune is finalized for the new turbos I assume get the turbos and the tune all in one shot.
Brian
