      04-28-2014, 09:10 PM   #45
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Originally Posted by YungDro View Post
youre comparing it to hypercars/supercars that was your point? lol
EDIT: Nevermind I understand now read your comment properly
      04-28-2014, 09:15 PM   #46
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
Originally Posted by LSM View Post
Not on 91 octane pump gas, you will see 30hp maybe...I run mine on mix of 100 octane pump gas and 91 octane pump gas and turned boost up to 2.75 which is really an increase of 3.96 over stock...Its crazy fast
you run 2.75 on 91? Figured out how to change PSI level?
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      04-28-2014, 09:33 PM   #47
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
I'm going to run mine on 93 pump gas with the with latest firmware at + 3psi. Thoughts?
My Thread:
      04-28-2014, 10:32 PM   #48
mr-karim
mr-karim's Avatar
I asked Terry, on the latest firmware +3psi = +2.5psi on the older version.
No difference at all, I didn't even update.
      04-28-2014, 10:52 PM   #49
Hunter5179
Hunter5179's Avatar
OK perfect. What about install? I don't find the instructions to clear. I wish they were better.
My Thread:
      04-28-2014, 10:56 PM   #50
Schnell_1
Schnell_1's Avatar
23
Drives: 2013 F13
If you were to run just 91, would boost would you recommend?
      04-28-2014, 10:58 PM   #51
mr-karim
mr-karim's Avatar
for 91 octane use +2.25 over stock
for 93 octane use +2.5 over stock
      04-28-2014, 10:59 PM   #52
mr-karim
mr-karim's Avatar
Install the new update or the BMS piggyback itself?
There is a nice manual for installing bms, in pdf format I think. If u want to update, I can help you out, very easy
      04-28-2014, 11:04 PM   #53
Schnell_1
Schnell_1's Avatar
23
Drives: 2013 F13
Old firmware? If yes, then 3 PSI with new firmware, correct?
      04-28-2014, 11:07 PM   #54
mr-karim
mr-karim's Avatar
Yup on old. If you got the new firmware from Terry, then use +2.5 psi on 91, and +3 psi with 93
      04-29-2014, 11:31 AM   #55
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
Mr Karim, I have the old firmware, so what ever number we put in is times 1.44.....I mix 100 octane pump gas and 91 octane pump gas 50/50 ratio so Im at 95.5 octane with the mix and run 2.75 x 1.44 = 3.96 boost over stock...The car is significantlty faster than when running 2.25...Going to dyno soon to see the results. I hit 590whp at 2.25 and a mix of 1/4 100 octane and 3/4 91 so was around 93 octane. I only have BMS and charcoal filter delete. I fullly expected to hit 620ish WHP with current set-up of the 50/50 fuel mix and 2.75 setting, it feels that much faster LOL
2024 Porsche 911 GTS Cabriolet
      04-29-2014, 11:32 AM   #56
LSM
LSM's Avatar
2.25 as Mr Karim stated and expect probably 20hp gain and 30 lb/ft
      04-29-2014, 11:33 AM   #57
LSM
LSM's Avatar
Thats exactly correct on the latest firmware
