      09-04-2016, 04:32 AM   #1
PhilGT2008
Drives: M6 Gran Coupe
M6 exhaust options.
Hello all, at the moment I have the exhaustmeister fitted on my stock M6 GC and it really has helped the sound. I still have the stock exhaust. It still isn't enough for me though. What is my next option? Akropivic seems to get a lot of feedback bit are there cheaper nearly as good options? Should I decat the stock?
I am looking louder.
      09-04-2016, 03:59 PM   #2
S800vxr
Drives: F13 M6 Coupe
Decat downpipes will add a large chunk of sound. Adding a full Akro to that will wake the devil. Mine does anyhow! 😎
      09-04-2016, 04:51 PM   #3
speedracerlo
Drives: 2015 M6 Gran Coupe
There isn't much alternative to the musical tone of the Akropovic. M Performance system is cheaper of course, but still on the expensive side. I would suggest taking the cat out, but if you are a mature man you will not like the smell.
      09-05-2016, 07:47 AM   #4
PhilGT2008
Smell?
I also drive a Lotus so smell of petrol or whatever you are referring to doesnt bother me.
      09-05-2016, 09:16 AM   #5
melvyn
Drives: 2018 M3 CS
Originally Posted by PhilGT2008 View Post
Smell?
I went for the MPE which is made by Akra but am not sure if it's toned down a bit, regardless if it is it still sounds the business and have had a lot of comments about it.
A little vid below will give you some idea to sound , it's through the internal mic on GoPro so there is some wind noise
      09-05-2016, 11:31 AM   #6
2007 to 2016 M6 Cab
Drives: 2019 M2 Competition HS
Smell?
Once the cats are gone - the exhaust small will be much more noticeable ...
Going Catless and downpipes will give you more of a turbo spool sound which is cool ... but the CEL will illuminate a lot of the time due to emissions, thus the smell ... and the growl is only slightly better.
After doing the Super Sprint Catless Downpipes ... I eventually did the Akra
Turner Muffler Delete may be an option as well
Current Garage:
2019 M2 Comp, 2019 GLC 63 AMG , 2017 GLS 63 AMG, 2015 S63 Amg, 2008 John Dheer Gator XUV
Past Cars:
2016 M6 Cabrio, 2015 GLK 250 Bluetec, 2007 M6 Cab, 2011 S63 Amg, 2008 S450, 2006 330xi, 1998 Z24, 2002 Chev Suburban
      09-05-2016, 08:11 PM   #7
TrevorM3
Drives: 6.3 AMG
akra is overpriced.
do the downpipes.
      09-05-2016, 10:34 PM   #8
2007 to 2016 M6 Cab
Originally Posted by TrevorM3 View Post
akra is overpriced.
do the downpipes.
and try turner muffler delete as well
Current Garage:
Past Cars:
      09-06-2016, 07:08 AM   #9
PhilGT2008
To clarify - downpipes decat will throw the emissions light? Not sure I can be bothered with that. Or is there a workaround?
      09-06-2016, 08:30 AM   #10
2007 to 2016 M6 Cab
Yes ... going catless will throw the emissions light ... not many after market tuning options will be able to adjust or override this problem.
Mine goes off occasionally only to return later
Current Garage:
Past Cars:
      09-06-2016, 09:16 AM   #11
DentalBoy
DentalBoy's Avatar
50
Drives: 2016 M6 Gran Coupe
I personally like Meisterschaft! It sounds awesome ,You can adjust the sound via the remote control and is a fraction the cost of Akra..
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold)
2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled!
E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold
E39 M5 UUC short shift,UUC Corsa and More Sold
      09-06-2016, 10:38 AM   #12
Eurohorses
Eurohorses's Avatar
503
Drives: 23 Jahre G80 M3
My Meisterschaft exhaust was just delivered. I'm currently running Gintani catless downpipes and have completed the Exhaust Flap mod but it still didn't produce the sound the M6 should be making. I will report back once i have them installed.
I did get the valved version, which allows me to quiet things down in the even its too loud, but i doubt that will be the case. I just wanted to have the option.
JB4 will also arrive this week and I will head over to Enzo to get a stacked tune. I'm hoping it all comes together as planned.
      09-06-2016, 11:12 AM   #13
speedracerlo
Well I've never seen a check engine light because when I installed my fabworx catless DPs I got the PP Performance Stage II tune and so far sooo goood.
      09-06-2016, 10:08 PM   #14
2007 to 2016 M6 Cab
Yeap .. I did Dinan stage II due to warranty concerns ... but that CEL
Current Garage:
Past Cars:
      09-07-2016, 02:32 AM   #15
lamespoon
Drives: 428i
so you have the dinan tune and a catless exhaust?
how's the power on that/whats your overall opinion on it?
      09-07-2016, 08:39 AM   #16
2007 to 2016 M6 Cab
The People at Dinan say I am over 700 Hp now and about 670 ft lbs ... I get a bit more wheel hop under acceleration, meaning the power output is just at the point to overpower the stability/traction control.
Butt dyno suggests it has a lot of get up and go, and the car feels lite on the track now.
It was expensive, but warranty was key for me.
The Carbon fibre intakes for stage II also are very nice!
Current Garage:
Past Cars:
      09-07-2016, 08:20 PM   #17
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
I chirped the wheels when flooring it at 90mph
      09-08-2016, 12:12 AM   #18
2007 to 2016 M6 Cab
that ain't a bad thing
Current Garage:
Past Cars:
kris1858555.00
      09-08-2016, 03:12 AM   #19
Justin.AutoTalent
Drives: F80 M3
If you like the tone of the stock exhaust and just want a little more sound, you should try downpipes
We will be installing a set of downpipes soon, I'll be sure to take a clip
      09-08-2016, 07:11 AM   #20
PhilGT2008
Where do I buy downpipes? (UK here) but if there is a USA seller who can ship that is also fine.
      09-15-2016, 03:38 PM   #21
PhilGT2008
Anyone?
      09-16-2016, 12:37 AM   #22
2007 to 2016 M6 Cab
Anyone?
There should be a Super Sprint Distributor in your area .. I did the Super Sprint Catless Down Pipes ... the turbo spool sound is intoxicating
Current Garage:
Past Cars:
