08-21-2016, 09:06 AM | #1 |
Rep 51
bike rack
Any experience with bike rack on GC with M Paket? I found some info on
http://www.motor-talk.de/forum/zwei-...78.html?page=1 it seems that it should be possible to install the OEM click on system even on the car with M Paket (even though it is officially not possible), other option is sea sucker?does it work with sunroof? Thanks! |
09-08-2016, 02:36 PM | #3 |
Rep 98
I enquired when I first purchased my gran coupe and there was a problem with getting part of the kit and then there was the cost which was eye wateringly expensive when you too into account labour to fit it. All of which was on the assumption that it would fit an M-sport car which the parts system said it didn't so the dealer said no.
In the end I went (very sceptically) for a seasucker which has so far been very good for the trips I've done with it. Still makes me worry every time I use it but I get to the destination with the right number of bikes each time so can't grumble. |
09-09-2016, 02:02 AM | #4 |
Rep 51
Thank you very much for your reply- do you have sun roof too? I read that it should be ok with seasucker...I need to carry up to three bikes, so i should probably go with - https://www.seasucker.com/shop/bomber/#tab-description
Which one do you have? |
09-09-2016, 01:08 PM | #5 |
Rep 98
I do have a sun roof and put the seasucker on glass roof and then onto the back back window.
It fits nicely however the glass panel isn't wide enough for the bomber only the mini bomber so that would possibly be the limiting factor there. I'm pretty sure bomber outer cups would be over the roof ditch finisher so will never gain suction due to the change in panels. |
