11-21-2016, 08:11 AM | #1 |
Rep 536
Wheel size question
Will this fit on the F13 without rubbing?
Wheel size: 20" Width: 10.5J (Rear) & 9J (Front) Offset: ET27 (Rear) & ET20 (Front) |
11-25-2016, 10:31 AM | #4 |
Rep 1,719
M5 rear offset is as much as a non m 6 series can handle. Use the offset calculator to compare. It's a 10 inch wheel with I believe a 33 offset?
11-25-2016, 11:48 AM | #5 |
Rep 536
11-25-2016, 08:05 PM | #6 |
Rep 194
you found your own answer, but just to concur, there's no way these would fit. the 10.5" rear works, but you're about 15mm too far out. a +35 is about the absolute limit before rubbing becomes a big problem with a 10.5
11-26-2016, 01:15 AM | #7 |
Rep 6,067
Neither of them work. Even 343M (M6) with lighter ET won't work on F13 640i/650i
11-26-2016, 02:31 PM | #8 |
Rep 1,719
The M5 343 wheel works, but not the M6 343. They are different widths and offsets.
11-26-2016, 02:32 PM | #9 |
Rep 1,719
