      12-10-2022, 04:18 PM   #1
PhantomXone
Drives: F06 640i GC & E46 M3
Did a muffler delete but now I get too much drone at low RPM
Just installed a new diffuser & decided to do a muffler delete on my 640i. Sounds great but at low RPM I can hear a pretty loud drone inside my car which sucks. Would adding one or two resonators back there help tone down the drone at all? I also have a catted downpipe coming soon as well. any info will help thanks!
      12-21-2022, 11:39 PM   #2
F-0H6
Drives: F06 640i
looks great man. i want to delete my mufflers as well so cant help about the drone. did you cut out the resonators or just the mufflers?
      12-22-2022, 10:53 AM   #3
PhantomXone
Thanks bro! Just the mufflers were deleted
      12-22-2022, 01:35 PM   #4
e38740imd
Drives: 2016 640i
https://vibrantperformance.com/ultra...onators-v1249/
this will fix your issue. pick the correct piping size. get the correct part number, buy on amazon
      12-22-2022, 10:43 PM   #5
PhantomXone
You think one is enough or do I need two?
      12-22-2022, 10:52 PM   #6
e38740imd
Drives: 2016 640i
1 if you slit to both sides
2 if you put one on each side
Imho. 1 is good enough.
You decide
      01-02-2023, 12:48 PM   #7
F15FromHell
F15FromHell's Avatar
Drives: 2018 BMW X5 Xdrive50i Msport
Xpipe
      01-05-2023, 12:55 PM   #8
PhantomXone
I'm actually getting one resonator installed right now on one side to see if it helps reduce the drone. I'll update you guys to see how it goes
      01-06-2023, 10:10 AM   #9
PhantomXone
Ok it worked! Added only one to the left side and after driving it home after work the drone is very minimal! Woooo!
Praying when I put on the downpipe the drone doesn't come back haha
      05-29-2023, 03:50 PM   #10
aopthof
Drives: Alpine B6
Having the same problem after deleting my mufflers. Horrible drone around 2.000 rpm. How is the end result. You stayed with a single resonator or installed a second one after all?
      06-01-2023, 10:16 AM   #11
PhantomXone
The drone was reduced to a tolerable tone. Still running a single resonator for now & I'm fine with it
      06-07-2023, 11:26 AM   #12
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Did the same on mine. It actually doesn't bother me much, maybe I'm nuts
